Webdav doesn't works fully. Permissions issue?
I created webdav access in one of my domains. However seems like some file creation of deletion doesn’t work. I get “405 Not Allowed” on using multiple clients.
Strangelly sometimes directories and files can be created, deleted etc - most times - not.
I used this toturial Installing and Configuring a WebDAV Server on Ubuntu 22 | Reintech media and used custom “Web Template APACHE2” with values mentioned in article and my own directories, so authentication and some file/directory creation is working.
EDIT: after some debuging, seems files like .html, .txt and known extentions can be created, but not edited/deleted. BUT unknown extensions like for example file “test.qweqwe” can be deleted…
What can i try solve this? Any workaround? Thanks.
We don’t support Webdav and probably because Nginx it might get blocked.
