WebDomains do not serve
I can ping the domains to the website, panel etc. But for some reason i cannot access the sites. Apache2 is online, Nginx is stuck on old IP and does not work.
I think it is Nginx, how do i go ahead on changing the old IP as hestiaCP did not automatically do this?
I changed the IP of the vps, and now it does not work. When i try to restart nginx it says
an 10 15:58:42 web-de-1 systemd[1]: Starting nginx - high performance web server…
Jan 10 15:58:42 web-de-1 nginx[164575]: nginx: [emerg] bind() to 178.63.197.251:80 failed (99: Cannot assign requested address)
Jan 10 15:58:42 web-de-1 systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Jan 10 15:58:42 web-de-1 systemd[1]: nginx.service: Failed with result ‘exit-code’.
Jan 10 15:58:42 web-de-1 systemd[1]: Failed to start nginx - high performance web server.
And I have also changed IP for all web domains and removed the old IP from settings.
Did you use the command v-update-sys-ip to change the ip?
You can use this command to check the files that are still using the old ip:
grep -RF 178.63.197.251 /etc/nginx/
I have also ran this command v-update-sys-ip, but it still not changed automatically.
I have changed the IP, Nginx is now working, but the sites cannot be loaded but has Internal Server Error.
You must check the logs to view the actual error. For the example.net domain, the log should be located at /var/log/apache2/domains/example.net.error.log
upstream timed out (110: Connection timed out) while connecting to upstream
Thats the error i got, I restarted vps and restarted the PHP-FPM as others had the same issue, but thats all error i got.
Check whether apache2 is using the old ip:
grep -RF 178.63.197.251 /etc/apache2/
etc/apache2/mods-available/remoteip.conf: RemoteIPInternalProxy 178.63.197.251
Replace it with the actual ip and restart apache2.
It works now thank you so much :3
