All my webmail subdomains are returning the text “No input file specified.” and it returns a 404 error
What logs I need to check to solve this problem?
/var/log/nginx/webmail.domain.com.log /error log
/var/log/roundcube
After more than 6 hours trying to figure out what happened:
The problem was a php configuration, the parameter open_basedir must be empty for roundcube. if you need to change it, just edit the /etc/php/X.X/fpm/pool.d/domain.conf or the template associated to that domain.
Gracias por el consejo. Me paos igual. Habia modificado el open_basedir global y no lo recordaba.
