Webmail page don't found
when trying to access webmail it says page not found.
I don’t change url slug in settings.
What could it be?
thanks and regards!
How do you try to access webmail? More informations are gold :stuck_out_tongue:.
i try default webmail url… https://webmail.domain.com.
Mails are working and i receive in mobiles, outlook, etc But when open webmail says page dont found
obviusly ssl instaled.
Should work, it adds custom configuration for webmail. Is it present? /home/user/conf/mail/domain/apache2.conf or nginx.conf
Can you check if both webservices are restarting properly?
/home/user/config. there is nothing :grimacing:
You need to replace “user” with your username ofc…
thanks , yes i know sorry i try config no conf , in conf i found 3 directories /dns
/mail and /web
i try restart apache2 and nginx and both services restarting properly
webmail dont open for all users from panel
i compare this directories and files with other installation what webmail is working and aparently all have the same settings
nginx-error.log
/usr/local/hestia/log/nginx-error.log 5219/14800 35%2020/11/02 06:14:09 [error] 31326#0: *307 open() “/usr/local/hestia/web/stalker_portal/c/version.js” failed (2: No such file or directory), client: 178.62.50.152, server: _, request: “GET /stalker_portal/c/version.js HTTP/1.1”, host: “8x.xx.xx.xx:8083”
2020/11/02 06:14:10 [error] 31326#0: *310 “/usr/local/hestia/web/client_area/index.php” is not found (2: No such file or directory), client: 178.62.50.152, server: _, request: “GET /client_area/ HTTP/1.1”, host: “8x.xx.xx.xx:8083”
2020/11/02 06:14:10 [error] 31326#0: *313 FastCGI sent in stderr: “Primary script unknown” while reading response header from upstream, client: 178.62.50.152, server: _, request: “GET /system_api.php HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “8x.xx.xx.xx:8083”
How can I add ssl to my email, I only need that.
Create also webmail.domain.com
Or wildcard (*.domain.tld) CNAME DNS record.
page webmail.domain.com dont found and nothing changed on route /webmail.
Nbody found this?
i am with same situatio, please help me…
Check your DNS webmail.domain.com should point to the server…
