Transferred from VestaCP to HestiaCP
Created a new user account at my HestiaCP
Installed WordPress on my domain (Working Page with working login)
I transferred my current working website to my new HestiaCP account i created.
Transferred successfully and imported database.
Problem
Website does not load anymore. Only able to see the Hestia Welcome message.
Your new web server is ready to use.
I should be able to see my normal main website instead this welcome page. How can i resolve this problem?
System
AWS EC2
EDIT: Ubuntu 18.04 LTS
Basic HestiaCP installation
Thanks in advanced
Lupu
October 24, 2019, 9:49am
2
Have you installed HestiaCP on centos ? or is that a typo?
Lupu
October 24, 2019, 10:19am
4
That success page is shown when the requested web domain is unknown or when you access trough the server ipaddress.
How did you transfer the website from VestaCP did you use backup and restore on HestiaCP or other method?
Tristan
October 24, 2019, 10:21am
5
I have my backups at managerWP which works normally all the time. I also transferred an other website to my new HestiaCP with using manageWP and that one work without any problems for some reason.
Only one website have this problem…
Lupu
October 24, 2019, 10:23am
6
I see that your website is up, have you found a solution?
Tristan
October 24, 2019, 10:24am
7
No, i transferred it to my previous host… I will transfer it back to HestiaCP once there is a solution for my problem.
Tristan
October 24, 2019, 10:27am
8
I will remove the user and domain later… And try it again and hopefully it is working this time
Lupu
October 24, 2019, 11:16am
9
When adding the web domain, double check the alias also, and make sure cloudflare is forwarding correctly to the right web domain (i’m not familiar with how couldflare should work here)
Tristan
October 24, 2019, 2:37pm
10
Yeah that did the trick… Must have overseen it… Thanks Lupu for pointing me to the edit Alias idea
jssaid
February 2, 2021, 10:48pm
11
Hello, can you please explain how you fix your issue, same problem here, I migrated from vestacp, now I deleted all files and folders but I´m getting this error
Success!
My public_html is empty
I see the same issue with hesiaCP
