Hello I have the following problem. The websites all go offline after about a day although Apache and Mysql are running. You can still get into the panel and everything looks fine.
Yesterday the server was restarted and the websites still stayed offline. After 30 minutes without doing anything everything went online again.
The problem occurs now only after I updated Hestiacp from 1.2.4 to 1.3.2.
Another error I found in Hestia SSL at ISSUER: C = US, ST = California, L = San Francisco, O = Hestia Control Panel, OU = IT, CN = server.domain2.com, emailAddress =
Suddenly there is another domain in here. “Server.” is correct but domain2.com is not correct. Why did this change? I do not know since when the change is in the domain also runs on the server but has nothing to do with the panel. If the server crashes because of this I can’t say.
Errorlogs:
2021-01-07 13:34:56 0 [ERROR] InnoDB: (Duplicate key) writing word node to FTS auxiliary index table.
2021-01-07 13:34:56 0 [Note] InnoDB: FTS optimize thread exiting.
2021-01-07 13:34:56 0 [Note] InnoDB: Starting shutdown…
2021-01-07 13:34:56 0 [Note] InnoDB: Dumping buffer pool(s) to /var/lib/mysql/ib_buffer_pool
2021-01-07 13:34:56 0 [Note] InnoDB: Buffer pool(s) dump completed at 210107 13:34:56
2021-01-07 13:34:58 0 [Note] InnoDB: Shutdown completed; log sequence number 124208327823; transaction id 294646515
2021-01-07 13:34:58 0 [Note] InnoDB: Removed temporary tablespace data file: “ibtmp1”
2021-01-07 13:34:58 0 [Note] /usr/sbin/mysqld: Shutdown complete
Apache:
[Sat Jan 09 15:38:18.677721 2021] [mpm_prefork:error] [pid 1128] AH00161: server reached MaxRequestWorkers setting, consider raising the MaxRequestWorkers setting
