I’m trying to work out why the SSL’s are not renewing on a server. The websites work ok, but the mail domains are not renewing. Is it /usr/local/hestia/bin/v-update-letsencrypt-ssl that handles this? Are there any tests I can do to see why its not working?
Which showed me there were a couple of others that were not working right. So I reset those, and all good now. The issue I think came from when an update run. I have a script I run that “fixes” up the nginx /apache templates to add in the ipv6 listeners, otherwise LE fails. But this time when nginx changed, it changed the “SSL http2” to “SSL”, which broken my script. I fixed that up quickly, but I guess not before the LE stuff had tried to renew and failed multiple times
