If I posted a bunch of output code/log with no formatting, no highlights of what I want to show, no explanation of what I did or what I’m expecting to see and what happens, I wouldn’t expect anyone to reply to me. Just my two cents…
Hello, The form below works with vestacp, However I want to make it work with Hestia.
(Create a button to login directly into the panel).
I am guessing this is happening because the Username and password are no more in the same form (In HestiaCP).
<form action="https://demo.vestacp.com:8083/login/" method="post" target="_blank">
<input type="hidden" name="user" value="admin" />
<input type="hidden" name="password" value="Apheiz6aifaiJag" />
<input type="submit" value="Login to Control Panel" />
</form>
Hope you guys can help.
Hestia != VestaCP…
Session token is not set…
I am a fan of HestiaCP, this is a grandiose panel in which there is nothing superfluous and everything your heart desires. I also had a problem with WHMCS. After a long search, I managed to find a module that fully meets the requirements. The module is called WHMCS Module HestiaCP. Here you can read the documentation and features of the module
Mod Edit: Advertising isnt allowed.
Please do not bump old topics…
