hello
I tried using vesta whmcs but now it is not responding.
I tried https://docs.hestiacp.com/admin_docs/rest_api.html?highlight=whmcs but couldn’t find a solution.
I would really appreciate if you can help.
Thank you very much, stay healthy.
hello
For readablity please do not post under 9 months old posts. But create an new one.
Any error while using the VestaCP WHMCS Plugin
<?php
// This module sponsered by our good friends from wexcloud.com
function vesta_ConfigOptions() {
$configarray = array(
"Package Name" => array( "Type" => "text", "Default" => "default"),
"SSH Access" => array( "Type" => "yesno", "Description" => "Tick to grant access", ),
"IP Address (optional)" => array( "Type" => "text" ),
return $configarray;
function vesta_CreateAccount($params) {
// Execute only if there is assigned server
if ($params["server"] == 1) {
// Prepare variables
$postvars = array(
'user' => $params["serverusername"],
'password' => $params["serverpassword"],
'hash' => $params["serveraccesshash"],
'cmd' => 'v-add-user',
'arg1' => $params["username"],
'arg2' => $params["password"],
'arg3' => $params["clientsdetails"]["email"],
'arg4' => $params["configoption1"],
'arg5' => $params["clientsdetails"]["firstname"],
'arg6' => $params["clientsdetails"]["lastname"],
$postdata = http_build_query($postvars);
// Create user account
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, 'https://' . $params["serverhostname"] . ':8083/api/');
curl_setopt($curl, CURLOPT_RETURNTRANSFER,true);
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($curl, CURLOPT_POST, true);
curl_setopt($curl, CURLOPT_POSTFIELDS, $postdata);
$answer = curl_exec($curl);
logModuleCall('vesta','CreateAccount_UserAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
// Enable ssh access
if(($answer == 'OK') && ($params["configoption2"] == 'on')) {
$postvars = array(
'cmd' => 'v-change-user-shell',
'arg2' => 'bash'
logModuleCall('vesta','CreateAccount_EnableSSH','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
// Add domain
if(($answer == 'OK') && (!empty($params["domain"]))) {
$postvars = array(
'cmd' => 'v-add-domain',
'arg2' => $params["domain"],
'arg3' => $params["configoption3"],
logModuleCall('vesta','CreateAccount_AddDomain','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
if($answer == 'OK') {
$result = "success";
} else {
$result = $answer;
return $result;
function vesta_TerminateAccount($params) {
$postvars = array(
'cmd' => 'v-delete-user',
// Delete user account
logModuleCall('vesta','TerminateAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_SuspendAccount($params) {
$postvars = array(
'cmd' => 'v-suspend-user',
// Susupend user account
logModuleCall('vesta','SuspendAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_UnsuspendAccount($params) {
$postvars = array(
'cmd' => 'v-unsuspend-user',
// Unsusupend user account
logModuleCall('vesta','UnsuspendAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_ChangePassword($params) {
$postvars = array(
'cmd' => 'v-change-user-password',
// Change user package
logModuleCall('vesta','ChangePassword','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_ChangePackage($params) {
$postvars = array(
'cmd' => 'v-change-user-package',
'arg2' => $params["configoption1"]
logModuleCall('vesta','ChangePackage','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
function vesta_ClientArea($params) {
$code = '<form action="https://'.$params["serverhostname"].':8083/login/" method="post" target="_blank">
<input type="hidden" name="user" value="'.$params["username"].'" />
<input type="hidden" name="password" value="'.$params["password"].'" />
<input type="submit" value="Login to Control Panel" />
<input type="button" value="Login to Webmail" onClick="window.open(\'http://'.$serverhostname.'/webmail\')" />
</form>';
return $code;
function vesta_AdminLink($params) {
<input type="hidden" name="user" value="'.$params["serverusername"].'" />
<input type="hidden" name="password" value="'.$params["serverpassword"].'" />
</form>';
return $code;
function vesta_LoginLink($params) {
echo "<a href=\"https://".$params["serverhostname"].":8083/login/\" target=\"_blank\" style=\"color:#cc0000\">control panel</a>";
function vesta_UsageUpdate($params) {
$postvars = array(
'cmd' => 'v-list-users',
'arg1' => 'json'
// Get user stats
// Decode json data
$results = json_decode($answer, true);
// Loop through results and update DB
foreach ($results AS $user=>$values) {
update_query("tblhosting",array(
"diskusage"=>$values['U_DISK'],
"disklimit"=>$values['DISK_QUOTA'],
"bwusage"=>$values['U_BANDWIDTH'],
"bwlimit"=>$values['BANDWIDTH'],
"lastupdate"=>"now()",
),array("server"=>$params['serverid'], "username"=>$user));
It is or the server access hash or the user (always admin) / server password
What values dit you provide (Please use dummy data)
params will be filled in whmcs backend. @gunka eris asked for logs, what exactly is your issue? What’s the error message you got? Did you checked the web log for additional informations?
Module
Vesta
User name
admin
Password
Are you just copy&pasting?
As you said, I choose vesta panel in the whmcs servers section and there I enter the ip username and password, but,
command reports operation failed.
Ok, and in the web server logs? Is the backend port 8083 open, can you reach it for example with curl? We can’t take over the debug work for you
In the past, this code I sent to vesta was successful, it was working, after the updates it was working about 8 months ago.
I want to automatically create accounts in whmcs, delete, freeze, etc.
Welcome to the Hestia Control Panel
User name
Previously, the user name and password came together, now the user name comes first. Could it have something to do with it?
Vesta != Hestia, even when the api should be the same. Probaly you’ve a connection issue, but as written: We can’t debug it for you nor provide the needed sysadmin skills.
You mean the installation output or in the whmcs backend?
Normally, if the code we use in vesta whmcs is valid, I wonder if it works now, then there is a problem with my settings
the whmcs backend
No idea, the whmcs module is not from us, it’s still vesta base. It could or can work, because the api is still the same.
I am entering as admin while creating a user, I wonder if there may be an authorization restriction.
You could try to validate the api connection manualy to gain more informations: https://docs.hestiacp.com/admin_docs/rest_api.html
<?php
$postvars = array(
logModuleCall('hestia','CreateAccount_UserAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
$postvars = array(
'arg2' => 'bash'
logModuleCall('hestia','CreateAccount_EnableSSH','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
// Add domain
$postvars = array(
logModuleCall('hestia','CreateAccount_AddDomain','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
$postvars = array(
logModuleCall('hestia','TerminateAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
$postvars = array(
logModuleCall('hestia','SuspendAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
$postvars = array(
logModuleCall('hestia','UnsuspendAccount','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
$postvars = array(
logModuleCall('hestia','ChangePassword','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
$postvars = array(
logModuleCall('hestia','ChangePackage','https://'.$params["serverhostname"].':8083/api/'.$postdata,$answer);
} else {
$result = $answer;
return $result;
<input type="submit" value="Hestia giriş" />
<input type="button" value="web mail girişi" onClick="window.open(\'https://webmail.'.$params["domain"].'/\')" />
<input type="button" value="Phpmyadmin giriş" onClick="window.open(\'https://'.$params["domain"].'/phpmyadmin\')" />
</form>';
return $code;
</form>';
return $code;
echo "<a href=\"https://".$params["serverhostname"].":8083/login/\" target=\"_blank\" style=\"color:#cc0000\">Hestia panel</a>";
$postvars = array(
'arg1' => 'json'
// Get user stats
// Decode json data
See my last comment
