I have a custom .sh script , which has all my ipv6 rules in (that I want to be added back in after a reboot). So I have:
root@2024:/usr/local/hestia/data/firewall# ls -lh
total 20K
-rw-rw---- 1 root root  141 Jan 10 13:50 banlist.conf
-rw-rw---- 1 root root  269 Jan 10 13:50 chains.conf
-rwxr-xr-x 1 root root 1.4K Jan  9 15:09 custom.sh
drwxr-xr-x 2 root root 4.0K Dec 30 06:45 ipset
-rw-r--r-- 1 root root    0 Dec 30 13:51 ipset.conf
-rw-r--r-- 1 root root 2.1K Jan  9 15:03 rules.conf
This is the contents of custom.sh:
#!/bin/bash
# ip6tables single-host firewall script
# Define your command variables
ipt6="/sbin/ip6tables"
# Flush all rules and delete all chains
# for a clean startup
$ipt6 -F
$ipt6 -X
# Zero out all counters
$ipt6 -Z
# Default policies: deny all incoming
# Unrestricted outgoing
$ipt6 -P INPUT DROP
$ipt6 -P FORWARD DROP
$ipt6 -P OUTPUT ACCEPT
# Must allow loopback interface
$ipt6 -A INPUT -i lo -j ACCEPT
# Reject connection attempts not initiated from the host
# $ipt6 -A INPUT -p tcp --syn -j DROP
# Allow return connections initiated from the host
$ipt6 -A INPUT -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
# Accept all ICMP v6 packets
$ipt6 -A INPUT -p icmpv6 -j ACCEPT
# Optional rules to allow other LAN hosts access to services. Delete $ipt6 -A INPUT -p tcp --syn -j DROP
# Allow DHCPv6 from LAN only
$ipt6 -A INPUT -m state --state NEW -m udp -p udp -s fe80::/10 --dport 546 -j ACCEPT
# Allow connections from SSH clients
$ipt6 -A INPUT -m state --state NEW -m tcp -p tcp --dport 22 -j ACCEPT
$ipt6 -A INPUT -m state --state NEW -m tcp -p tcp --dport 22122 -j ACCEPT
# Allow HTTP and HTTPS traffic
$ipt6 -A INPUT -m state --state NEW -m tcp -p tcp --dport 80 -j ACCEPT
$ipt6 -A INPUT -m state --state NEW -m tcp -p tcp --dport 443 -j ACCEPT
# Allow access to SMTP, POP3, and IMAP
$ipt6 -A INPUT -m state --state NEW -p tcp -m multiport --dport 25,110,143 -j ACCEPT
If I manually run it, it works fine:
root@2024:~# ip6tables --list -n
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
root@2024:~# bash /usr/local/hestia/data/firewall/custom.sh
Chain INPUT (policy DROP)
ACCEPT     all      ::/0                 ::/0
ACCEPT     all      ::/0                 ::/0                 ctstate RELATED,ESTABLISHED
ACCEPT     icmpv6    ::/0                 ::/0
ACCEPT     udp      fe80::/10            ::/0                 state NEW udp dpt:546
ACCEPT     tcp      ::/0                 ::/0                 state NEW tcp dpt:22
ACCEPT     tcp      ::/0                 ::/0                 state NEW tcp dpt:22122
ACCEPT     tcp      ::/0                 ::/0                 state NEW tcp dpt:80
ACCEPT     tcp      ::/0                 ::/0                 state NEW tcp dpt:443
ACCEPT     tcp      ::/0                 ::/0                 state NEW multiport dports 25,110,143
Chain FORWARD (policy DROP)
root@2024:~#
Yet when I reboot, it doesn’t. Is there any way I can debug? I’m assuming v-update-firewall does indeed run on a server reboot?
Andy
