Where to change beta to stable?
1.6.0 has been released if you want to switch over to “stable”
remove the hash infront of :slight_smile:
deb [arch={$arch} signed-by=/usr/share/keyrings/hestia-keyring.gpg] https://apt.hestiacp.com/ {codename} main
And add it infront of
deb [arch={arch} signed-by=/usr/share/keyrings/hestia-beta.gpg] https://beta.hestiacp.com {codename} main
Then run apt update
In which file?
/etc/apt/sources.list.d/hestia.list
If you did an new install change Hestia-beta.list instead
I have two files:
hestia-beta.list:
deb [arch=amd64 signed-by=/usr/share/keyrings/hestia-beta-keyring.gpg] https://beta.hestiacp.com/ jammy main
hestia.list
#deb [arch=amd64 signed-by=/usr/share/keyrings/hestia-keyring.gpg] https://apt.hestiacp.com/ jammy main
What i need to do?
Both file not have string what i need. Difference in “jammy main” and arch.
Codename and arch are depending on architecture / OS. That’s why I used {arch} and {codename} as varaibles…
Add hash to:
And remove:
Then apt update
Big thank!
