I’ve noticed in Hestiacp 1.9.2 there is no option to white label Footer text:
It is not possible and I think it is really reasonable to keep it there…
Hi eris,
But I think this makes white label meaningless!
I think we allow more than any other panel allow for white labeling with out require any payment for it…
U still can clone the project and build it on your own.
Its a good open source panel, why do you want to strip it completely of its identity? Anyway you are welcome to donate a massive amount and maybe they will consider it ![]()
As @Raphael mentioned, you can always fork and run it as you like. You can temporarily change it here > /web/templates/includes/app-footer.php (#L4 & #L5) and reload the server & apache/nginx. This will however be overwritten upon updates, if using direct HCP and not your own fork.
