ΒΏWhy Clamav-Daemon stop?
How can I do so that the service does not stop continuously? I can activate without problem but after a short time the service stops again
Check the logs
where can i check the log for Clamav Daemon ?
/var/log, but you should know that when you’re running a server on your own.
Probably CPU/RAM insufficient.
As of my trst, hestia need atleast 2GB ram for clamAV+SPAMASS+DOVECOT
I have some problem with one server, parameters is well but clamav-daemon stops itself
How to add cron in hestia panel for strating service by timer?
Logs doesn’t show anything, just stop at 12.12 and start manually 15/12
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxEmbeddedPE limit set to 10485760 bytes.
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxHTMLNormalize limit set to 10485760 bytes.
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxHTMLNoTags limit set to 2097152 bytes.
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxScriptNormalize limit set to 5242880 bytes.
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxZipTypeRcg limit set to 1048576 bytes.
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxPartitions limit set to 50.
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxIconsPE limit set to 100.
Mon Dec 12 01:35:59 2022 β†’ Limits: MaxRecHWP3 limit set to 16.
Mon Dec 12 01:35:59 2022 β†’ Limits: PCREMatchLimit limit set to 10000.
Mon Dec 12 01:35:59 2022 β†’ Limits: PCRERecMatchLimit limit set to 5000.
Mon Dec 12 01:35:59 2022 β†’ Limits: PCREMaxFileSize limit set to 26214400.
Mon Dec 12 01:35:59 2022 β†’ Archive support enabled.
Mon Dec 12 01:35:59 2022 β†’ AlertExceedsMax heuristic detection disabled.
Mon Dec 12 01:35:59 2022 β†’ Heuristic alerts enabled.
Mon Dec 12 01:35:59 2022 β†’ Portable Executable support enabled.
Mon Dec 12 01:35:59 2022 β†’ ELF support enabled.
Mon Dec 12 01:35:59 2022 β†’ Mail files support enabled.
Mon Dec 12 01:35:59 2022 β†’ OLE2 support enabled.
Mon Dec 12 01:35:59 2022 β†’ PDF support enabled.
Mon Dec 12 01:35:59 2022 β†’ SWF support enabled.
Mon Dec 12 01:35:59 2022 β†’ HTML support enabled.
Mon Dec 12 01:35:59 2022 β†’ XMLDOCS support enabled.
Mon Dec 12 01:35:59 2022 β†’ HWP3 support enabled.
Mon Dec 12 01:35:59 2022 β†’ Self checking every 3600 seconds.
Mon Dec 12 01:35:59 2022 β†’ Listening daemon: PID: 25582
Mon Dec 12 01:35:59 2022 β†’ MaxQueue set to: 100
Mon Dec 12 03:06:47 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 04:27:52 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 05:42:55 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 06:53:08 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 08:04:17 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 09:07:12 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 10:25:46 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 11:33:44 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 12:35:49 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 13:46:28 2022 β†’ SelfCheck: Database status OK.
Mon Dec 12 14:00:11 2022 β†’ Reading databases from /var/lib/clamav
Thu Dec 15 01:09:40 2022 β†’ +++ Started at Thu Dec 15 01:09:40 2022
How many memory?
I have some servers with similar configs, only this one has a problem
CPU 4 cores | RAM 4 GB
I think if start clamav by cron, it can be solved
I added to cron task (/etc/init.d/clamav-daemon restart)
Maybe it will be enough to do once a day
