hi,
i added cron in my hestia control panel but why not execute my cron. if i add to /etc/crontab then work fine but not work if add cron from hestia control panel.
sudo /usr/bin/python3 /home/admin/script.py
thank you,
hi,
thank you,
sudo is the problem, you want to run it with root permissions which admin doesnt directly have…
