hi . A week ago I changed the Control Panel of my VPS server from Vesta to Hestia. I don’t know the reason but in the health of the WordPress site it gives me the following error. I have accepted port 443 in the firewall and restarted the server, but I can’t get the WordPress Wp-cron.php to work, could you help me? Thanks . Sincerely : Pau Company
where is the error ?
Port 443 is open by default and shouldn’t need to open it
Check if ping domain.com works fine of on your computer and doesn’t strangely fail…
ping domain.com on your server and see what fails
If you have basic auth activated on your site, (eg if access to the general public is blocked in .htaccess or via a plugin). then WP is unable to access the cron.php file.
In this case you can keep WP quiet by adding a cron job in Hestia cron settings for that user, as suggested by WP forum.
