Wordpress-disable-xmlrpc
how can i install this templates ?
Hestiacp now has documentation:
Just download them with wget and install them in the correct folder
hey i already saw these files inside the /usr/local/hestia/data/templates/web/nginx/php-fpm/
but its not showing on the panel UI
do i need to move them to /usr/local/hestia/data/templates/web/nginx/ ?
and i installed the panel using default settings nginx + apache2
