nugie
#1
After I am performing wordpress installation, than i trying to redirect into wordpress login page given url than it 404 not found.
url : example.com/wp-login.php
Than it appear 404 not found
Would you pleased to give me some advice? Thank you very much . .
eris
#2
Nginx make sure you enable wordpress template
nugie
#3
Would you pleased to give me the way how to perform it?
nugie
#5
In my control panel :
Web Template APACHE2
and the option just only default
ScIT
#6
Should work out of the box, how did you installed wordpress?
nugie
#7
Hi, I am installing wordpress from Quick Install.
nugie
#8
I am facing the same problem yesterday after wordpress installlation via quick install, than in the next day that problem fixed by itself.
Ubi
#9
2nd issue in a row solved by itself. You are lucky man!
nugie
#10
It going same problem that after wordpress installation, the login page just 404 not found, but after next day it appear by itself.
nugie
#11
How do I enebled web template with nginx? On my control panel was web template with apache2
eris
#13
Simple answer remove Apache2. How ever currently not supported
nugie
#14
Actually, sometime we need apache2 for another application. So we cannot remove apache2.
