Hello.
My setup:
Serv Web: nginx
Serv Backend: php-fpm
php --ri gd
gd
GD Support => enabled
GD headers Version => 2.3.3
GD library Version => 2.3.3
FreeType Support => enabled
FreeType Linkage => with freetype
GIF Read Support => enabled
GIF Create Support => enabled
JPEG Support => enabled
PNG Support => enabled
WBMP Support => enabled
XPM Support => enabled
XBM Support => enabled
WebP Support => enabled
TGA Read Support => enabled
I also added the code to:
/etc/nginx/conf.d/domains/mydomain.ssl.conf
# BEGIN SMUSH-WEBP
location ~* "wp-content\/(uploads\/)(.*\.(?:png|jpe?g))" {
add_header Vary Accept;
set $image_path $2;
if (-f "/home/usr/web/mydomain.com/public_html/wp-content/smush-webp/disable_smush_webp") {
break;
if ($http_accept !~* "webp") {
break;
expires max;
try_files /wp-content/smush-webp/$image_path.webp $uri =404;
# END SMUSH-WEBP
and deactivated all image formats
the plugin still doesn’t work. anyone know the solution on how to effectively activate the plugin?
