Working reverse proxy (for me)
Hi there,
I was looking for a solution for reverse proxy within my local network, after looking for a week, I got it running with these templates:
location templates: /usr/local/hestia/data/templates/web/nginx
tpl:
server {
            error_log   /var/log/%web_system%/domains/%domain%.error.log error;
                    deny all;
                    return 404;
            location / {
                    proxy_pass http://192.168.1.2:51821;
            location @fallback {
                    proxy_pass http://%ip%:%web_port%;
            location /error/ {
stpl:
server {
            listen      %ip%:%proxy_ssl_port% ssl;
            # TLS 1.3 0-RTT anti-replay
                    deny all;
                    return 404;
            location / {
Works likes a charm :slight_smile:
afaik you should delete these two stapling lines…
Will do that :slight_smile:
I got a question, do you know hw I can setup a reverse proxy to another ip adress that uses 80 & 443 and already has letsencrypt installed on the other server.
