Quickly checked the server, and everything is up on Hestia’s server list page - but is this a sign that something is fundamentally wrong and the server is about to die?
not enough information. especially about your server/setup. is this ovz/lxc by any chance? probably running out of memory and/or the OOM-reaper is killing processes.
have you set up some swap at least?
I see. I was expecting this to rather be a vps and not a dedicated
OVZ/LXC are containerization methods (as opposed to KVM for full virtualization). obviously that doesn’t apply here then and the RAM usage also is fairly low.
yes, a segmentation fault is nothing you want to see then. if possible, maybe restart into rescue mode and run some memtest …
