WP Rocket Error 500 Fix on Hestia CP
I was getting a 500 Internal Server Error when clearing the cache in WooCommerce (using WP Rocket).
I modified the NGINX configuration and it solved the issue for now.
Here are the changes I made:
proxy_buffers 256 4k; to 4 256k
proxy_buffer_size 32k; to 128k
proxy_busy_buffers_size 32k; to 256k
After applying these, the error disappeared.
My question is:
Are these values safe and optimal to apply globally on other server work as well, especially when using WooCommerce ?
Thank you!
Hi @vipvip
I would use something more flexible:
proxy_buffers               16 64k;
proxy_buffer_size           128k;
proxy_busy_buffers_size     512k;
And maybe you should modify gzip_buffers too:
gzip_buffers 32 16k;
