Wsgi+python plugin?
Good afternoon.
We use wsgi +python flask.
Is there a plugin for this?
And it turns out by default only php can be used - applications can be used …
No there is currently no plugin for it.
Maybe this will help:
Thank you very much, read, got acquainted. I realized that it’s easier to create your own pattern for Apache2. Created, I can now choose the “Flask” template. Configuration files /home/user/conf/web/domain/apache2.ssl.conf are now generated correctly. Thanks!
