hestiacp/CHANGELOG.md at main · hestiacp/hestiacp · GitHub See changes logs
Hi
hestia port being 2083
I’ve asked SSL to CLOUDFLARE
and i works fine for me, with HTTPS, HSTS, proxy, encryption full
before pasting the certificates in HESTIA, I had to apply this:
wget https://developers.cloudflare.com/ssl/static/origin_ca_rsa_root.pem
mv origin_ca_rsa_root.pem origin_ca_rsa_root.crt
cp origin_ca_rsa_root.crt /usr/local/share/ca-certificates
update-ca-certificates
then, copy/paste the keys from CLOUDFLARE in
- admin > server > configure > SSL (the certificates won’t show after Save)
- domain’s SSL certificate
in case it blocks, I try . .
v-add-letsencrypt-host
/usr/local/hestia/bin/v-add-letsencrypt-host
OR
sudo /usr/local/hestia/bin/v-update-host-certificate user sub.domain.net
reboot
It force you to use Cloudflare if you can’t / don’t want it is not an option.
User should update his server to more recent version Ubuntu 22.04 or 20.04
is there command in SSL putty , to update my ubuntu be higher ? i need suggesstion about this … if i have updatede my ubuntu… is there newest hestiacp update for new version ? or is it enough just update ubuntu only ?
Yes you can update hestia the the latest version
thks very much… i want to try
i have on step reboot
but ubuntu still on 16, not 18… is there detail command that i can follow as gudance to upgrade ?
sudo do-release-upgrade -c (command not found ) … what must i do to solve this ?
Google for instruction for 16.04 their have changes been made.
THKS SSL is clear after i update UBUNTU 22
