My “Advanced Options” page on web, dns pages etc. does not open. Does anyone know what could be wrong and how to fix it? My problem is connected to this forum topic. Because I assume that modified templates is reffered to on this page!?
And my current version and updates status is as follows (but else everything works just fine):
Yes, I have tried, but then I loose every setting on the sites and https stops working with wildcard certificate on them. Upgrading by sudo apt update && sudo apt upgrade and that’s works fine (also by turning on automatic updates in HestaCP works ok). But all certificate settings get’s fucked up.
Hi, how do a specifically use the v-change-domain-tpl to change apache2 modified template, nginx modified template, phpcgi modified template for a given site?
How are we gonna use the v-change-domain-tpl in details, with examples?
To me, the command seems only to handle templates for complete web site. If so, how are we gonna tell how to change …nginx/default_new.stpl, nginx/default_new.tpl, apache2/default_new.stpl, apache2_new.tpl etc. to be used by HestiaCP with this cli command?
Shall the cli commands be run as hestiacp admin?
I get permission errors:
/usr/local/hestia/func/main.sh: line 1539: /usr/local/hestia/conf/hestia.conf: Permission denied
Error: invalid template format :: /usr/local/hestia/data/templates/web/apache2/default_new.tpl
/usr/local/hestia/func/main.sh: line 100: /usr/local/hestia/log/error.log: Permission denied
And I still cannot open “Advanced Options” in HestiaCP GUI, even if I now have updated to:
It’s most problably a bug in HestiaCP koncerning the “Advanced Options” page.
For ex. on the web configuration page:
When entering the web configuration for the 1st time, toggling the “Advanced Options” does not work
Then the advanced options is only start working when you first press “show certificates”. After that toggling the “Advanced Options” works fine, even if you have “show certificates” in different states.
I you only have checked “Enable Automatic HTTPS redirection”, you don’t have link to “show certificates” (as in my case). Therefore you cannot get the “Advanced Options” button to start working. You have to temporarily check som of the other checkboxes, for ex. “Use Let’s Encrrypt to obtain certificate”, to get it to start working.
Does not work from start depending on initial settings in the web config page
