How to retain Let'ts encrypt wildcard certificates and fullchain ca certificate
How should we avoid sites being completely overwritten in HestiaCP update, especially when using certificates (wildcard and fullchain ca certificate) generated on another server on the internet, and then transfered securely to HestiaCP server, and then ssl certificates in sites are symlinked to an central folder with the received certificates.
Can we do any special update procedure, or configure the sites in hestia to not replace everything on an update?
Create custom templates
https://docs.hestiacp.com/admin_docs/web.html#how-do-web-templates-work
Thanks! But where do i tell hestia to use my copied and modified templates?
Is it in Hestia CP? Below web? I can not see that have any option for it!?
The advanced page does not open for me either, but that’s maybe normal?
