After updating mariadb, my.cnf disappears and a symbolic link appears
Hello everyone, I often encounter such a difficulty after updating mariadb, namely, a file with My.cnf settings disappears, and a symbolic link appears. Accordingly, the parameters are completely reset. What I am doing, deleting a symbolic link, and throw my.cnf reserve file into the directory /etc /mysql. In general, I wonder if there is an opportunity to avoid this after each database update? Thank you . Has anything changed since then?)
cd /etc/mysql && rm my.conf && cp /usr/local/hestia/install/deb/mysql/my-large.cnf /etc/mysql/my.cnf && systemctl restart mariadb && systemctl status mariadb
Hi @bestperson
mariadb-common package does this when installing/updating:
    if ! update-alternatives --query my.cnf | grep --quiet "Value: /etc/mysql/mariadb.cnf"
    then
      update-alternatives --install /etc/mysql/my.cnf my.cnf "/etc/mysql/mariadb.cnf" 500 || true
    fi
That means that if my.cnf is not a symbolic link pointing to mariadb.cnf, it will be recreated.
The solution is to put your config in mariadb.cnf and create the symbolic link.
rm -f /etc/mysql/my.cnf
cp /usr/local/hestia/install/deb/mysql/my-large.cnf /etc/mysql/mariadb.cnf
ln -rsf /etc/mysql/mariadb.cnf /etc/mysql/my.cnf
Thank you, everything is so, of course, it would be good that the creators of the database are somehow thought out so that you do not create a file every time)
I checked, today after updating the database, all settings have been preserved. Thanks a lot!
