Settings of Maria BD became empty after updating on hestia cp
Hello!
  1. I found that settings for mariadb editing became empty
  2. It is for 3-4 different server looks similar
  3. Before i remember data in fields:
max_connections
max_user_connections
wait_timeout
interactive_timeout
max_allowed_packet
  1. Plus config file became so:
The MariaDB configuration file
The MariaDB/MySQL tools read configuration files in the following order:
0. “/etc/mysql/my.cnf” symlinks to this file, reason why all the rest is read.
1. “/etc/mysql/mariadb.cnf” (this file) to set global defaults,
2. “/etc/mysql/conf.d/*.cnf” to set global options.
3. “/etc/mysql/mariadb.conf.d/*.cnf” to set MariaDB-only options.
4. “~/.my.cnf” to set user-specific options.
If the same option is defined multiple times, the last one will apply.
One can use all long options that the program supports.
Run program with --help to get a list of available options and with
–print-defaults to see which it would actually understand and use.
If you are new to MariaDB, check out Basics | Server | MariaDB Documentation
This group is read both by the client and the server
use it for options that affect everything
[client-server]
Port or socket location where to connect
port = 3306
socket = /run/mysqld/mysqld.sock
Import all .cnf files from configuration directory
!includedir /etc/mysql/conf.d/
!includedir /etc/mysql/mariadb.conf.d/
5)Was before:
[client]
port=3306
socket=/var/run/mysqld/mysqld.sock
[mysqld_safe]
[mysqld]
user=mysql
pid-file=/var/run/mysqld/mysqld.pid
port=3306
basedir=/usr
datadir=/var/lib/mysql
tmpdir=/tmp
lc-messages-dir=/usr/share/mysql
log_error=/var/log/mysql/error.log
symbolic-links=0
local-infile=0
skip-external-locking
key_buffer_size = 256M
max_allowed_packet = 32M
table_open_cache = 256
sort_buffer_size = 1M
read_buffer_size = 1M
read_rnd_buffer_size = 4M
myisam_sort_buffer_size = 64M
thread_cache_size = 8
query_cache_size= 16M
#innodb_use_native_aio = 0
innodb_file_per_table
max_connections=200
max_user_connections=50
wait_timeout=10
interactive_timeout=50
long_query_time=5
  1. Sites works well, but it is normal practice or not?
In a standard Hestia install, I make any adjustments in
/etc/mysql/mariadb.conf.d/50-server.cnf
Generally max_connections is one I’ll want to reduce from the default
Well, i can work calm now? If everything works normally
Maybe if there are many sites and server needs to reduce power need to add limits in settings
I am having the same problem too, all the MariaDB GUI parameters are now empty, don’t know what update made this change since I haven’t seen this screen in a long time.
MariaDB overwrites my.cnf still a know issue
I need to do a change to the innodb_buffer_pool_size, where would I do that now? Or how do I fix the overwrite issue for now?
rm my.conf
cp /usr/local/hestia/install/deb/mysql/my-large.cnf /etc/mysql/my.cnf
and reload
thanks. this just appeared to fix my ‘blank settings’ for
Configure Server: MYSQL
I’ve had some persistent OOM errors that popup once every 2-4 months.
It would be cool if we had SOME sort of ‘watchdog script’.
just once a minute, if mysql isnt’ started.. then start it.
IF IT fails, then wait and try again after 2 minutes
then 4 minutes.. etc
That’s how I was taught to retry database connections about 25 years ago.
THANKS guys. for all you guys do. I’m embarrassed I didn’t do this long ago.
