Autoreply is not being sent over SMTP Relay
Hello, i’m trying to setup the autoreply for the holiday season.
If I use the option within HestiaCP it works -but- the message isn’t being sent over the SMTP relay that I have setup for that account… Is this a known problem, anything I can do about it?
If I use the Sieve filter option as described here the reply message doesn’t appear in the exim4 logs. I tried both with and without x-spam-flag.
Basicly known yes, its the same issue for forwarded messages - also doesnt get shipped over smtp relay.
Just curious: I read that you made a custom installation for it. Would it be a lot of work / big investment to make smtp relay work for auto reply (preferably with setup through Roundcube / Imap) and forwarding? I read it has been discussed before being perhaps a donation-based feature.
I am here for the same reason in 2024, autoreply is not being forwarded over SMTP relay.
Thank you so much Chris, I will look into it
