For one of our hesticap server, the backups module is missing from the menu… also in server file manager, the backups folder is showing as empty… however the server disk space usage is 99% from df-h command, where the user account is of only 28gb out of 200gb available in server… what could be wrong here ? I was trying to recover some space by removing backups, but cannot find any… Is there anyway to fix this without reinstalling server ?
I could find exim4 logs taking up around 6gb which i just cleaned.
But any clue about why backup modules is not showing up in hestiacp dashboard menu ?
I have auto updates for hestiacp enabled…
executed and rebooted the server…
now facing another issue - hestiacp login page changed to another theme with blue bg
unable to login, it goes on loop after entering password, asks username again.
also to clear up space, cannot find any file under /backup using ls command
Hi As of now there is over 30gb diskspace, But I am not able to login to Hestiacp admin panel, after entering the username and pass, it asks the same again, and this works in a loop… How to fix this ? Also the login page bg is now blue instead of regular black theme. Please advise
