Bug & Suggested Fix for Let’s Encrypt Hooks
Hi dear HestiaCP Community!
I posted some months ago a detailed info regarding this issue here:
Let’s Encrypt Hooks
I suppose nobody took note of it because it was a reply to a topic with given solution.
However, it came out that this fix only works for the first time cert creation. Later renewals would not execute the hook!
I explained in detail there why the present solution does not work.
Finally, I also suggested a very simple fix.
I have also add a comment in github, where the feature was introduced:
It is indeed no big change.
I (and many others for sure) would be thankful if you could apply this fix into the next release.
Thank you and best regards!
Hi @teoli
Check this PR:
Great!
this would be even better :slight_smile:
Let’s hope this goes through. The previous option should then be removed; otherwise, it leads to confusion.
