I was using hestia cp for like 2 months, but today it stopped working. I can not login to my to my Hestia cpanel anymore, after login it just going back to username input like nothing happened. If i input wrong username or password it shows it.
After trying to reinstall by using apt install hestia --reinstall and I got these errors in SSH.
PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/mai
n.php on line 527
PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web
/inc/main.php on line 528
PHP Warning: Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 1
05
PHP Warning: Undefined array key "APP_NAME" in /usr/local/hestia/web/inc/mail-wrapper.php on line
32
v-list-sys-config json shows this:
"config": {
"WEB_SYSTEM": "apache2",
"WEB_RGROUPS": "www-data",
"WEB_PORT": "8080",
"WEB_SSL": "mod_ssl",
"WEB_SSL_PORT": "8443",
"WEB_BACKEND": "php-fpm",
"PROXY_SYSTEM": "nginx",
"PROXY_PORT": "80",
"PROXY_SSL_PORT": "443",
"FTP_SYSTEM": "vsftpd",
"MAIL_SYSTEM": "exim4",
"IMAP_SYSTEM": "dovecot",
"ANTIVIRUS_SYSTEM": "",
"ANTISPAM_SYSTEM": "spamassassin",
"DB_SYSTEM": "mysql",
"DNS_SYSTEM": "bind9",
"DNS_CLUSTER": "",
"DNS_CLUSTER_SYSTEM": "hestia",
"SUPPORT_DNSSEC": "yes",
"STATS_SYSTEM": "awstats",
"BACKUP_SYSTEM": "local",
"CRON_SYSTEM": "cron",
"DISK_QUOTA": "no",
"FIREWALL_SYSTEM": "iptables",
"FIREWALL_EXTENSION": "fail2ban",
"FILE_MANAGER": "true",
"REPOSITORY": "",
"VERSION": "1.8.11",
"RELEASE_BRANCH": "release",
"UPGRADE_SEND_EMAIL": "true",
"UPGRADE_SEND_EMAIL_LOG": "false",
"SMTP_RELAY": "",
"SMTP_RELAY_HOST": "",
"SMTP_RELAY_PORT": "",
"SMTP_RELAY_USER": "",
"DEMO_MODE": "",
"THEME": "dark",
"LANGUAGE": "en",
"BACKUP_GZIP": "4",
"BACKUP": "/backup",
"BACKUP_MODE": "zstd",
"WEBMAIL_ALIAS": "webmail",
"WEBMAIL_SYSTEM": "roundcube",
"DB_PMA_ALIAS": "phpmyadmin",
"DB_PGA_ALIAS": "",
"LOGIN_STYLE": "default",
"INACTIVE_SESSION_TIMEOUT": "60",
"PHPMYADMIN_KEY": "",
"ENFORCE_SUBDOMAIN_OWNERSHIP": "yes",
"DEBUG_MODE": "false",
"API": "yes",
"API_SYSTEM": "1",
"API_ALLOWED_IP": "",
"UPDATE_AVAILABLE": "",
"PLUGIN_APP_INSTALLER": "true",
"PLUGIN_FILE_MANAGER": "",
"POLICY_SYSTEM_ENABLE_BACON": "false",
"POLICY_SYSTEM_PROTECTED_ADMIN": "yes",
"POLICY_SYSTEM_HIDE_ADMIN": "",
"POLICY_SYSTEM_HIDE_SERVICES": "no",
"POLICY_SYSTEM_PASSWORD_RESET": "no",
"POLICY_USER_VIEW_SUSPENDED": "no",
"POLICY_BACKUP_SUSPENDED_USERS": "no",
"POLICY_USER_EDIT_DETAILS": "yes",
"POLICY_USER_EDIT_WEB_TEMPLATES": "yes",
"POLICY_USER_EDIT_DNS_TEMPLATES": "yes",
"POLICY_USER_DELETE_LOGS": "yes",
"POLICY_USER_VIEW_LOGS": "yes",
"POLICY_USER_CHANGE_THEME": "yes",
"POLICY_CSRF_STRICTNESS": "1",
"POLICY_SYNC_SKELETON": "yes",
"POLICY_SYNC_ERROR_DOCUMENTS": "yes",
"USE_SERVER_SMTP": "false",
"SERVER_SMTP_HOST": "",
"SERVER_SMTP_PORT": "",
"SERVER_SMTP_SECURITY": "",
"SERVER_SMTP_USER": "",
"SERVER_SMTP_PASSWD": "",
"SERVER_SMTP_ADDR": "[email protected]",
"DISABLE_IP_CHECK": "no",
"FROM_NAME": "",
"FROM_EMAIL": "",
"APP_NAME": "Hestia Control Panel",
"TITLE": "{{page}} - {{hostname}} - {{appname}}",
"SUBJECT_EMAIL": "{{subject}}",
"HIDE_DOCS": "no"
I see these errors at login page console
