Can't login after upgrade
I have the same error after upgrading. (Debian 10)
It is not possible to log in or change the password.
I try "/usr/local/hestia/bin/v-change-user-password admin" and delete the RKEY in user.conf
**I reset the computer using Time Machine. **
apt upgrade hestia liblz4-1 libx11-6 libx11-data nginx
Output:
[ ! ] IMPORTANT INFORMATION:
Default configuration files and templates may be modified or replaced
during the upgrade process. You may restore these files from:
**Backup directory: /root/hst_backups/300520211756/ **
**Installation log: /root/hst_backups/300520211756/hst-upgrade-300520211756.log **
[ ! ] Performing system health check before proceeding with installation…
[ ! ] Adding missing variable to hestia.conf: UPGRADE_SEND_EMAIL (‘true’)
[ ! ] Adding missing variable to hestia.conf: UPGRADE_SEND_EMAIL_LOG (‘false’)
[ ! ] Adding missing variable to hestia.conf: WEBMAIL_SYSTEM (‘roundcube’)
[ ! ] Adding missing variable to hestia.conf: INACTIVE_SESSION_TIMEOUT (‘60’)
[ ! ] Adding missing variable to hestia.conf: ENFORCE_SUBDOMAIN_OWNERSHIP (‘no’)
[ ! ] Adding missing variable to hestia.conf: API_ALLOWED_IP (‘allow-all’)
[ ! ] Adding missing variable to hestia.conf: ENFORCE_SUBDOMAIN_OWNERSHIP (‘yes’)
[ ! ] Adding missing variable to hestia.conf: DEBUG_MODE (‘false’)
[ ! ] Adding missing variable to hestia.conf: PLUGIN_APP_INSTALLER (‘true’)
[ ! ] Adding missing variable to hestia.conf: POLICY_SYSTEM_ENABLE_BACON (‘false’)
[ ! ] Adding missing variable to hestia.conf: POLICY_SYSTEM_HIDE_SERVICES (‘no’)
[ ! ] Adding missing variable to hestia.conf: POLICY_SYSTEM_PASSWORD_RESET (‘no’)
[ ! ] Adding missing variable to hestia.conf: POLICY_SYSTEM_PROTECTED_ADMIN (‘no’)
[ ! ] Adding missing variable to hestia.conf: POLICY_USER_CHANGE_THEME (‘yes’)
[ ! ] Adding missing variable to hestia.conf: POLICY_USER_DELETE_LOGS (‘yes’)
[ ! ] Adding missing variable to hestia.conf: POLICY_USER_EDIT_DETAILS (‘yes’)
[ ! ] Adding missing variable to hestia.conf: POLICY_USER_EDIT_DNS_TEMPLATES (‘yes’)
[ ! ] Adding missing variable to hestia.conf: POLICY_USER_EDIT_WEB_TEMPLATES (‘yes’)
[ ! ] Adding missing variable to hestia.conf: POLICY_USER_VIEW_LOGS (‘yes’)
[ ! ] Adding missing variable to hestia.conf: POLICY_USER_VIEW_SUSPENDED (‘no’)
[ ! ] Adding missing variable to hestia.conf: PHPMYADMIN_KEY (’’)
[ * ] Health check complete. Starting upgrade from 1.3.5 to 1.4.1…
[ * ] Backing up existing templates and configuration files…
[ - ] Now applying any necessary patches from version v1.4.0…
[ * ] Enabling nginx FastCGI cache support…
[ * ] Updating nginx configuration with changes to Cloudflare IP addresses
[ * ] Populating HELO/SMTP Banner value for existing IP addresses…
[ * ] Updating exim4 configuration…
[ * ] Enabling SMTP relay support…
[ * ] Creating known good configuration data for system recovery…
[ * ] Removing outdated nginx templates…
[ * ] Migrating legacy default package for all users…
[ * ] Replacing default package…
[ - ] Now applying any necessary patches from version v1.4.1…
[ * ] Updating File Manager…
[ ! ] Updating default web domain templates…
[ ! ] Updating default mail domain templates…
[ ! ] Updating default DNS zone templates…
[ ! ] Verifying phpMyAdmin v5.1.0 installation…
Installation tasks complete, performing clean-up…
[ * ] Rebuilding user accounts and domains, this may take a few minutes…
** - admin…**
[ * ] Restarting services…
Upgrade complete! If you encounter any issues or find a bug,
please take a moment to report it to us on GitHub at the URL below:
Issues · hestiacp/hestiacp · GitHub
Best regards
Tom
Hi, just moved your thread, please do not revive 6 month old threads - the issue isnt related. Mayve this thread can help: After latest update can't login into admin panel
Hello ScIT,
1.) “passwd admin”
2.) “/usr/local/hestia/bin/v-change-user-password admin”
3.) “delete the RKEY=’ ’ in user.conf”
doesn´t help.
Best regards
Tom
Linked wrong post, try this one: Admin login problem after automatic upgrade to 1.4.1
