Clamav and spamassassin
I did a new installation and ClamAV and spamassassin are installed by default.
Since ClamAV is using a lot of memory, I would like to disable that.
  1. Is it possible to disable that now the installation is done?
  2. How can I do a new installation without ClamAV and without spamassassin?
Thanks. Ph.
See Getting Started — Hestia Control Panel documentation
So add: --spamassassin no --clamav no
Can I still now remove those packages?
Replace:
ANTISPAM_SYSTEM='spamassassin'
ANTIVIRUS_SYSTEM='clamav-daemon'
With:
ANTISPAM_SYSTEM=''
ANTIVIRUS_SYSTEM=''
in /usr/local/hestia/conf/hestia.conf
And in /etc/exim4/exim4.conf.template replace
SPAMASSASSIN = yes
SPAM_SCORE = 50
SPAM_REJECT_SCORE = 100
CLAMD = yes
With
#SPAMASSASSIN = yes
#SPAM_SCORE = 50
#SPAM_REJECT_SCORE = 100
#CLAMD = yes
restart exim4 service
And run apt remove clamav spamassassin
Thank you, it’s fine now.
