Clear unstall Ubuntu 22.04
If using install param:
wget https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh;
bash hst-install.sh
–-port 19859
default port for Hestia not changed.
check if v-change-sys-port 19859 changes the port properly or if you have aby output
root@master:~# v-change-sys-port 19859
sed: can’t read /usr/local/hestia/data/firewall/chains.conf: No such file or directory
installed on command:
bash hst-install.sh
–apache no
–phpfpm yes
–multiphp no
–named no
–vsftpd no
–proftpd no
–iptables yes
–fail2ban no
–quota no
–exim no
–dovecot no
–spamassassin no
–clamav no
–mysql yes
–postgresql no
–lang ru
–-port 19859
–-interactive no
-–force
after
port changed on new.
it’s a bug, @eris has it already fixed with Fix bug in v-change-sys-port by jaapmarcus · Pull Request #2982 · hestiacp/hestiacp · GitHub
