SFN
1
When I try to use any commands from the documention: https://docs.hestiacp.com/cli_commands/panel_configuration_commands.html I keep getting “bash: v-check-user-password: command not found” for example.
I have “/usr/local/hestia/bin” in my $PATH, but why does it keep saying command not found?
Latest version of HestiaCP
Debian 10
eris
2
Did you login into the server from a different ssh account?
Just checked when I login with my non root account…
**eris@cp** : **~** $ bash v-change-user-password
/usr/local/hestia/bin/v-change-user-password: line 18: /usr/local/hestia/conf/hestia.conf: Permission denied
Usage: v-change-user-password USER PASSWORD
/usr/local/hestia/func/main.sh: line 73: /usr/local/hestia/log/error.log: Permission denied
**eris@cp** : **~** $ sudo -s
root@cp:/home/eris# v-change-user-password
v-change-user-password: command not found
And on a different server where I use root to login in…
root@cp:~# bash v-change-user-password
You can always use /usr/local/hestia/bin/v-change-user-password
Lupu
3
Hello @SFN , try switching to the root user using sudo su -, all cli cmds should be available in your path after
SFN
4
Same thing with root.
root@debianmach:~# v-change-user-password
bash: v-change-user-password: command not found
As a normal user without sudo:
With sudo: “sudo: v-change-user-password: command not found”
eris
5
If you add the following lines in /root/.bashrc
if [ "${PATH#*/usr/local/hestia/bin*}" = "$PATH" ]; then
. /etc/profile.d/hestia.sh
fi
It will work when you login with sudo -s
For sudo command:
Alter the secure_path variable
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin"
to
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/usr/local/hestia/bin"
thanks to @Lupu how ever no guarantees given and on your own risk…
I have succeeded by typing the whole path:
example:
/usr/local/hestia/bin/v-rebuild-users
Excellent! simple, and it works.
