I have an issue where the custom document root doesn’t seem to be working even though it is set in the control panel and i still get the “Success your web server is ready”
I’d initially added the document root and there was a typo in the document root so it wouldn’t allow it since the directory didn’t exist. I corrected the the type and it saved successfully but now it’s stuck on the web server page.
I get the same problem without the custom document root, the 2 sites i added before these are still working with the custom document root which is also weird.
Deleting the user and add the web domain results in the same error, as well so at the moment no new users or websites can be added without getting that error
Sorry i didn’t mean a specific error message, i meant the issue of new user and sites now defaulting to the web server is ready message whilst exisiting sites and user still work
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using vps.*********.com. Set the ‘ServerName’ directive globally to suppress this message
I have resolved this issue. My mistake was selecting invalid IP address when creating domain. When I change to second option it works. I wonder why IP Address dropdown show same label with different value (IP address)? Can I remove the first option?
