Hello guys, I can’t login to panel, when I enter user and passord nothing happend, same login page
in nginx-error.log file is this many lines:
[error] 420731#0: *220 FastCGI sent in stderr: “; PHP message: PHP Warning: PHP Request Shutdown: Write failed: Disk quota exceeded (122) in Unknown on line 0; PHP message: PHP Warning: PHP Request Shutdown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/usr/local/hestia/data/sessions) in Unknown on line 0
after that I add command v-delete-sys-quota and find this message
sed: -e expression #1, char 1: missing command
rm: cannot remove ‘//aquota.user’: Operation not permitted
rm: cannot remove ‘//aquota.group’: Operation not permitted
is that possible to fix this?
Hello @osmaster,
Could you check whether those files are immutable?
lsattr /aquota.*
If you see an i in the output, something like this:
----i--A------e------- /aquota.group
----i--A------e------- /aquota.user
then the files are immutable and you need to remove that immutable condition to be able to remove them.
chattr -i /aquota.user
chattr -i /aquota.group
And launch again v-delete-sys-quota
Good luck,
sahsanu
Hello @sahsanu, thank you so much for helping, yes exactly like this:
after commands chattr -i /aquota.user and chattr -i /aquota.group
this message:
chattr: Operation not permitted while setting flags on /aquota.user
chattr: Operation not permitted while setting flags on /aquota.group
I’m wondering whether quotaoff worked from v-delete-sys-quota. Could you please show the contents of /etc/fstab?
cat /etc/fstab
yes sure, here it is:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda2 during installation
UUID=7e3b9937-a509-4b94-aa0d-90dea464dbc9 / ext4 errors=remount-ro,usrquota,grpquota,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0 0 0
# /boot was on /dev/sda1 during installation
UUID=7c581c10-0deb-41d0-bb08-063536a68556 /boot ext4 defaults,noatime 0 0
There is a bug in v-delete-sys-quota it is not geting the right line where root dir / is mounted
It is checking both lines:
and
If you are in a hurry you can remove quotas manually (step by step like it is doing the script) or let me check whether I can solve it but I’m a bit bussy now, anyways, let me check.
Ok, let’s fix it… or try to do it
Backup original script:
cp $HESTIA/bin/v-delete-sys-quota $HESTIA/bin/v-delete-sys-quota.original
Now edit file $HESTIA/bin/v-delete-sys-quota and modify line 34:
This is what you will see in line 34:
lnr=$(cat -n /etc/fstab | awk '{print $1,$3}' | grep "$mnt$" | cut -f 1 -d ' ')
and you need to change that line by this:
lnr=$(cat -n /etc/fstab | awk '{print $1,$2,$3}' | grep -E "^[0-9]{1,}\s[^#].+$mnt$" | cut -f 1 -d ' ')
Edit: just in case you view above line splitted, above change is only 1 line.
Save the file and try to launch it again v-delete-sys-quota
same thing
rm: cannot remove '//aquota.user': Operation not permitted
rm: cannot remove '//aquota.group': Operation not permitted
/etc/fstab has been modified?
cat /etc/fstab
no, only opened once
UUID=7e3b9937-a509-4b94-aa0d-90dea464dbc9 / ext4 errors=remount-ro 0 0
Yes. it has been modified, seems the script has more bugs and it is not turning off quota in /.
Do these steps manually, if any of them fail, stop.
1.- Turn off quota in /
quotaoff /
2.- Delete aquota files
rm -f /aquota.user
rm -f /aquota.group
3.- Edit file /usr/local/hestia/conf/hestia.conf and replace DISK_QUOTA='yes' by DISK_QUOTA='no' and save the file.
And that should be all.
in hestia.conf there is already DISK_QUOTA='no'
after quotaoff / nothing happens and also after delete commands too, files must have been deleted.
but it worked! ))) thank you very much @sahsanu !!!
could this problem still be later?
You are welcome. I’m glad it is working fine now.
Apart from the first bug that we corrected, there is another bug in the way quotaoff is checked so quotaoff is not executed by the script and when it tries to remove the aquota files it can’t because quota is on yet. After that, it also changes hestia.conf so that is the reason it was alreay as no.
Sorry, I forgot one step, please remove this file:
rm -f /etc/cron.daily/quotacheck
It should work fine from now on, if you want to be sure, just restart the server and check that all is working fine.
if I want bring quotas back that in hestia.conf line gonna be changed to DISK_QUOTA=‘yes’?
now i’ve checked, one user set quotas to mails and it overfill, is that possible to block quotas that users cant change it?
No, you should use v-add-sys-quota command but it has the same problems as v-delete-sys-quota so don’t use it till the bugs are fixed.
Are you sure you are no using an admin user to view/modify the quotas of another user?
maybe I set few limits long time ago and forget it, now I clear all quotas for every user and if “they” change quotas this not will be problem yes?
