Domains verses IP Addresses
I am new to this Control Panel. But is there a way when adding a Web Domain to use Just an IP address, instead of a www.blah.com ?
I’m using this on Ubuntu 20.4 Local & would like to use Just IPs .
Thank-You for your time.
Sid
no, ips only isnt supported.
Ah. can you live the Host field bank instead ? Or is there a way to change the script ?
no, you cant leave it blank. Basicly you can rewrite it - hestia is open source and all the code is there, ut I cant give you a guide how to do so, it would not be an easy chanhe like “lets remove this line”, more a deep rewrite of a lot of parts.
Ok.
Thank-You.
I shall have a look into it.
Sid
Hello :~)
I found it , in a file web.conf :~) In $HESTIA/data/users/$User
I Changed the Domain = ’ ’ to the IP instead of the Domain address & the Alias= ’ ’ to Show the Name of my Local Code/Domain.
Best Regards
Sid :smiley:
will get overwritten on update due to user rebuild.
I’m not sure what you mean :~/
I have just added a new Domain & it stead the same.
Best Regards
Sid
