Don't know how phpmyadmin
Hello team , I am new to Hestia and I just installed it on my server
I had been unable to access phpmyadmin to setup database
Please I need help
I have tried to use the phpmyadmin button on the database page
It will say page not found
Also I don’t see the any link to click when I hover on the MySQL database as described in the documentation
I’m really lost
I have tried to use host name it still don’t work or maybe I don’t know how to type it correctly
https://hostname.com/phpmyadmin/
Please I can’t read this I only speak English
Go to yourhostname.com/phpmyadmin/
@ikehemmanuel
To access phpMyAdmin, simply navigate to:
http://yourhostname.com/phpmyadmin/
For example, if your domain name is abc.com, you can access phpMyAdmin by going to:
http://abc.com/phpmyadmin/
Ensure that your domain is properly pointing to your server before attempting to access the phpMyAdmin.
@ikehemmanuel when you hit the phpmyadmin in the Hestia panel does it bring up your web address as your domain.com/phpmyadmin or as an IP 192.168.5.4/phpmyadmin ?
Ok
Please if I want to change folder and file permission
How do I go about this??
If you want to ‘change folder and file permissions’?
Uh, that’s chmod.
But maybe you should ask a ‘new topic’ in a new thread?
Changing PhpMyAdmin is easy to change the URL via the front end.
What are you trying to accomplish?
If you don’t know how to chmod, you probably aren’t the target market for HestiaCP.
Hire someone that write for you,
think for you
