Enable to login to panel after v-restore
v-delete-user-2fa username in command line
v-delete-user-2fa username command not found… :frowning:
Thanks for your answer but it doesn’t work … Can I reset the control panel? I have been stopped for two days and tired of this loop … I would like to do it all over again if possible by resetting the control panel. How can I do?
Only a reinstall will reset everything a reinstall will not work…
Use then the full path:
/usr/local/hestia/bin/v-delete-user-2fa username
/usr/local/hestia/bin/v-change-user-password username newpassword
TVM but i have the same problem… can’t to enter in cp :frowning:
Welcome to Hestia Control Panel
Username
Next
Invalid username or password.
reset password not work :frowning:
another way to reset admin password please?
login ssh via your terminal
ssh [email protected]
with root or sudo user:
# passwd admin
enter new pass word
do NOT reset with passwd, this could also be your issue. Always use v-change-user-password, otherwise the password gets reseted during a rebuild.
/usr/local/hestia/bin/v-change-user-password admin newpassword
No wonder it not working as rebuilds will reset passwords… to what is know in Hestia…
TVM i did it now but, no working… im in this loop for some days… ufff
thanks @Raphael
then this might have been a past issue for me
but, as i mentioned, i wasn’t getting any password error message in return of my attempt to log in with admin
i haven’t restored the admin
as you might have read, i’m now waiting a how to restore without failing
enough disk space? there are much potential reasons for a login loop, have a look here in the forum.
me too, 5 days of great efforts and no way out
good luck
i’m at a point now where i’m avoiding ssh keys, 2fa, in order to restore a BACKUP in this machine
Impossible space I have a lot of this… but thanks punkyard other solution for this problem? ty all guys
so far i didn’t get an solution from the forum
i had to reinstall . .
and now i can’t restore my backups without this issue coming back each time
you can extract a package and manualy restore the content → Backups / Restore — Hestia Control Panel documentation
have you tried to look towards the firewall fail2ban?
