all of a sudden, no one can log in
common-password
i changed to sha256
auth log:
2022-08-07 17:57:17 admin 93.5.120.234 successfully logged in
2022-08-07 18:12:42 admin 93.5.120.234 successfully logged in
2022-08-07 18:12:43 admin 93.5.120.234 successfully logged in
2022-08-07 21:30:38 admin 93.5.120.234 successfully logged in
2022-08-08 10:20:27 admin 93.5.120.234 successfully logged in
hestia conf is not empty
i’ve used a different browser
nothing does
i was on cli uploading backups, when i tried to log back: impossible
i’ve looked around the forum and tried every option suggested
any other idea from someone?
eris
August 8, 2022, 11:30am
2
2FA enabled?
v-change-user-password admin newpassword
Enough disk space
no, it’s not enabled
largely enough disk space
the login page doesn’t display any message, it just reloads after clicking to validate credentials
for hestia/data/sessions, i have
drwxrwx--- 2 admin admin 4096 Aug 8 13:19 sessions
ran a reboot
Check if you have disabled cookies in your browser
no i don’t disable cookies in my 3 browsers and can access other web spaces, like this one …
is there another log file to check out?
i’ve just found this in
/usr/local/hestia/data/users/admin/system.log
ID='305' DATE='2022-08-08' TIME='13:29:24' LEVEL='Info' CATEGORY='Firewall' MESSAGE='Added service to firewall (Service: REC>
ID='306' DATE='2022-08-08' TIME='13:29:24' LEVEL='Warning' CATEGORY='Firewall' MESSAGE='Banned IP address 212.70.149.18.'
ID='307' DATE='2022-08-08' TIME='13:29:25' LEVEL='Info' CATEGORY='Firewall' MESSAGE='Added service to firewall (Service: REC>
ID='308' DATE='2022-08-08' TIME='13:29:25' LEVEL='Warning' CATEGORY='Firewall' MESSAGE='Banned IP address 212.70.149.66.'
ID='309' DATE='2022-08-08' TIME='13:29:25' LEVEL='Info' CATEGORY='Firewall' MESSAGE='Added service to firewall (Service: REC>
ID='310' DATE='2022-08-08' TIME='13:29:25' LEVEL='Warning' CATEGORY='Firewall' MESSAGE='Banned IP address 5.34.207.225.'
ID='311' DATE='2022-08-08' TIME='13:29:25' LEVEL='Info' CATEGORY='Firewall' MESSAGE='Added service to firewall (Service: REC>
ID='312' DATE='2022-08-08' TIME='13:29:25' LEVEL='Warning' CATEGORY='Firewall' MESSAGE='Banned IP address 5.34.207.52.'
ID='313' DATE='2022-08-08' TIME='13:29:25' LEVEL='Info' CATEGORY='Firewall' MESSAGE='Added service to firewall (Service: REC>
ID='314' DATE='2022-08-08' TIME='13:29:25' LEVEL='Warning' CATEGORY='Firewall' MESSAGE='Banned IP address 87.246.7.76.'
v-check-user-password admin
Usage: v-check-user-password USER PASSWORD [IP] [RETURN_HASH]
when i type in my browsers mydomain.com : ok
when i type mydomain.COM:2083
i get a new message from epic browser:
ERR_TUNNEL_CONNECTION_FAILED
helps would be very helpful please
i had every thing reinstalled and i’m blocked right after
didn’t have time to do the backups
sites are down
Check if all services are running.
thanks JL
i’ve reinstalled
again
i’ve reinstalled, exact same thing happens
i didn’t have time to do much …
on ubuntu 22, ssh key, last hestia, add users, one domain, upload backups, reload 2 or 3 times, and then blocked: login screen spins around without giving a message …
@jlguerrero can you tell me how i can check those services you’re mentioning?
I think it is v-list-sys-services
jlguerrero:
v-list-sys-services
thanks a lot, i appreciate
here is what i get back:
apache2 running 0 449 74
php8.0-fpm running 0 8 5
nginx running 0 14 74
bind9 running 0 58 74
exim4 running 0 40 3
dovecot running 0 0 3
clamav-daemon running 0.7 1270 74
spamassassin running 0 280 3
mariadb running 0 651 3
vsftpd running 0 223 3
cron running 0 0 3
ssh running 0 5 3
iptables running 0 0 0
fail2ban running 0.3 134 74
hi
it’s clearly when i import a backup that the login goes loop
i’ve v-restored only one user, not the admin that has been set manually
right after the restore, the panel asks for login and password, and goes on looping again
the file had been reset to : chmod admin:user as supposed
can you please give more help and advices?
thanks
eris
August 11, 2022, 3:16pm
21
Probably you admin password has the wrong encoding. Just restore the websites and not the admin user…
