Error 404 in MariaDB repository
On a Hetzner server with Debian 11 and HestiaCP 1.8.11 ready to upgrade to Debian 12:
# apt update
Hit:1 http://mirror.hetzner.de/debian/packages bookworm InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Get:5 http://mirror.hetzner.de/debian/packages bookworm-updates InRelease [52.1 kB]
Get:6 http://mirror.hetzner.de/debian/packages bookworm-backports InRelease [56.5 kB]
Hit:7 http://mirror.hetzner.de/debian/security bookworm-security InRelease
Hit:8 https://nginx.org/packages/mainline/debian bookworm InRelease
Ign:9 https://mirror.mva-n.net/mariadb/repo/10.6/debian bookworm InRelease
Hit:10 https://packages.sury.org/apache2 bookworm InRelease
Hit:11 https://packages.sury.org/php bookworm InRelease
Err:12 https://mirror.mva-n.net/mariadb/repo/10.6/debian bookworm Release
  404  Not Found [IP: 195.65.111.42 443]
Hit:13 https://apt.hestiacp.com bookworm InRelease
Get:14 http://mirror.hetzner.de/debian/packages bookworm-backports/main amd64 Packages [172 kB]
Reading package lists... Done
E: The repository 'https://mirror.mva-n.net/mariadb/repo/10.6/debian bookworm Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
# cat /etc/apt/sources.list
## Note, this file is written by cloud-init on first boot of an instance
## modifications made here will not survive a re-bundle.
## if you wish to make changes you can:
## a.) add 'apt_preserve_sources_list: true' to /etc/cloud/cloud.cfg
##     or do the same in user-data
## b.) add sources in /etc/apt/sources.list.d
## c.) make changes to template file /etc/cloud/templates/sources.list.debian.tmpl
# See http://www.debian.org/releases/stable/i386/release-notes/ch-upgrading.html
# for how to upgrade to newer versions of the distribution.
deb http://deb.debian.org/debian bookworm main
deb-src http://deb.debian.org/debian bookworm main
## Major bug fix updates produced after the final release of the
## distribution.
deb http://deb.debian.org/debian-security bookworm-security main contrib
deb-src http://deb.debian.org/debian-security bookworm-security main contrib
deb http://deb.debian.org/debian bookworm-updates main
deb-src http://deb.debian.org/debian bookworm-updates main
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
# deb http://deb.debian.org/debian bookworm-backports main
# deb-src http://deb.debian.org/debian bookworm-backports main
# cat /etc/apt/sources.list.d/mariadb.list
deb [arch=amd64 signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://mirror.mva-n.net/mariadb/repo/10.6/debian bookworm main
Is the URL correct?
Take a look to this post:
The first version of MariaDB that supports Debian 12 ‘bookworm’ is 10.11, so my line in /etc/apt/sources.list.d/mariadb.list remains:
deb [arch=amd64 signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/debian bookworm main
Thank you.
It also supports 10.11 and if you want to use 11.x don’t use 11.3, that is the development (non production) version.
Right! Corrected and thank you very much for the warning.
