Error: B2 binary for arm64 must be downloaded manually
Hello
I try to enable back blaze and got this error
Error: B2 binary for arm64 must be downloaded manually.
according to B2: command not found
I used command line too v-add-backup-host b2 bucketName keyID applicationKey
and got same error
I checked /usr/local/bin and it’s empty
so from where I can download b2 ? it need install via command line ? what is the command ?
Thank you in advance:)
https://www.backblaze.com/b2/docs/quick_command_line.html
is that’s the required to install ?
yes, it is.
Yes install via pip
