All my servers (6) have been upgraded tonight, and I’ve received mail from two of them requiring a Manual Action related to the Enhanced and Optimized TLS feature:
Manual Action Required [IMPORTANT]
To enable the "Enhanced and Optimized TLS" feature, we must update the NGINX configuration file (/etc/nginx/nginx.conf).
But for unknown reason or you edited it, may not be fully apply all the changes in this upgrade.
Please follow the default configuration file to sync it:
/usr/local/hestia/install/deb/nginx/nginx.conf
Backed up configuration file:
/root/..../conf/nginx/nginx.conf
But I dont understand exactly what I need to do, I need to copy /usr/local/hestia/install/deb/nginx/nginx.conf to /etc/nginx/nginx.conf and thats all? Only copy some lines of the config file?
But the base config file is /usr/local/hestia/install/deb/nginx/nginx.conf ? So that I need is use that file (copying to /etc/nginx/nginx.conf) and apply manual changes to that file?
Before the update I had my own values in /etc/nginx/nginx.conf set via the HestiaCP UI.
I really don’t want to bother with copying files. The question for @eris is: Is this “Enhanced and Optimized TLS” something that is urgently needed? (I assume that the bug will be removed during the next update right?). What happens if I don’t perform this manual action?
Have the same issue as the original poster and the notification is a little ambiguous. Is the first file listed the ‘live’ one, and is that the new recommended one; or is that my original and should I be replacing it with the backed up version which is the new one? It seems to be an important update, but it’s unclear as to what I need to do…
