This morning, exim4 restart fails. I don’t know if it was the last hestia update or the sieve filter installation from REQ: 'filters' in roundcube
My Server
Hestia Control Panel: v1.6.7
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
exim4 error message
root@SRV-NET-04:~# systemctl status exim4.service
● exim4.service - LSB: exim Mail Transport Agent
Loaded: loaded (/etc/init.d/exim4; generated)
Active: failed (Result: exit-code) since Wed 2022-08-10 08:54:57 CEST; 1min 33s ago
Process: 989413 ExecStart=/etc/init.d/exim4 start (code=exited, status=1/FAILURE)
CPU: 134ms
Aug 10 08:54:57 SRV-NET-04 systemd[1]: Starting LSB: exim Mail Transport Agent...
Aug 10 08:54:57 SRV-NET-04 exim4[989413]: Starting MTA:
Aug 10 08:54:57 SRV-NET-04 exim4[989655]: 2022-08-10 08:54:57 Exim configuration error:
Aug 10 08:54:57 SRV-NET-04 exim4[989655]: there are two transports called "dovecot_virtual_delivery"
Aug 10 08:54:57 SRV-NET-04 exim4[989657]: Invalid new configfile /var/lib/exim4/config.autogenerated.tmp, not installing
Aug 10 08:54:57 SRV-NET-04 exim4[989657]: /var/lib/exim4/config.autogenerated.tmp to /var/lib/exim4/config.autogenerated
Aug 10 08:54:57 SRV-NET-04 systemd[1]: exim4.service: Control process exited, code=exited, status=1/FAILURE
Aug 10 08:54:57 SRV-NET-04 systemd[1]: exim4.service: Failed with result 'exit-code'.
Aug 10 08:54:57 SRV-NET-04 systemd[1]: Failed to start LSB: exim Mail Transport Agent.
Content of /etc/exim4/exim4.conf.template
# Exim configuration file for Hestia Control Panel #
SPAMASSASSIN = yes
SPAM_SCORE = 30
SPAM_REJECT_SCORE = 100
CLAMD = yes
smtp_banner = $smtp_active_hostname
smtp_active_hostname = ${lookup dnsdb{>: defer_never,ptr=$interface_address}{${listextract{1}{$value}}}{$primary_hostname}}
add_environment = <; PATH=/bin:/usr/bin
keep_environment =
disable_ipv6 = true
domainlist local_domains = dsearch;/etc/exim4/domains/
domainlist relay_to_domains = dsearch;/etc/exim4/domains/
hostlist relay_from_hosts = 127.0.0.1
hostlist whitelist = net-iplsearch;/etc/exim4/white-blocks.conf
hostlist spammers = net-iplsearch;/etc/exim4/spam-blocks.conf
no_local_from_check
untrusted_set_sender = *
acl_smtp_connect = acl_check_spammers
acl_smtp_mail = acl_check_mail
acl_smtp_rcpt = acl_check_rcpt
acl_smtp_data = acl_check_data
acl_smtp_mime = acl_check_mime
.ifdef SPAMASSASSIN
spamd_address = 127.0.0.1 783
.endif
.ifdef CLAMD
av_scanner = clamd: /var/run/clamav/clamd.ctl
.endif
log_selector = +tls_sni
tls_advertise_hosts = *
# We test that $tls_in_sni is a valid domain, by an arbitrary email address [email protected] .
# Then, we extract the domain with a function that would fail if the email address is invalid.
# If the certificate exists, we will use it, otherwise the default certificate in /etc/ssl will be used.
tls_certificate = \
${if and {\
{ eq {${domain:foo@$tls_in_sni}} {$tls_in_sni}}\
{ exists{/usr/local/hestia/ssl/mail/$tls_in_sni.crt} }\
{/usr/local/hestia/ssl/mail/$tls_in_sni.crt}\
{/usr/local/hestia/ssl/certificate.crt}\
tls_privatekey = \
${if and {\
{ exists{/usr/local/hestia/ssl/mail/$tls_in_sni.key} }\
{/usr/local/hestia/ssl/mail/$tls_in_sni.key}\
{/usr/local/hestia/ssl/certificate.key}\
daemon_smtp_ports = 25 : 465 : 587
tls_on_connect_ports = 465
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 0s
ignore_bounce_errors_after = 2d
timeout_frozen_after = 7d
DKIM_DOMAIN = ${lc:${domain:$h_from:}}
DKIM_FILE = /etc/exim4/domains/${lookup{${lc:${domain:$h_from:}}}dsearch{/etc/exim4/domains/}}/dkim.pem
DKIM_PRIVATE_KEY = ${if exists{DKIM_FILE}{DKIM_FILE}{0}}
OUTGOING_IP = /etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/ip
SMTP_RELAY_FILE = ${if exists{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/smtp_relay.conf}}
SMTP_RELAY_HOST = ${lookup{host}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PORT = ${lookup{port}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_USER = ${lookup{user}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PASS = ${lookup{pass}lsearch{SMTP_RELAY_FILE}}
# Custom Filter
system_filter = /etc/exim4/system.filter
system_filter_user = Debian-exim
# ACL CONFIGURATION #
# Specifies access control lists for incoming SMTP mail #
acl_not_smtp = acl_not_smtp
begin acl
acl_not_smtp:
deny message = Website of user $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
ratelimit = 200 / 1h / $authenticated_id
warn ratelimit = 100 / 1h / strict / $authenticated_id
log_message = Sender rate [limitlog]: log / account / $authenticated_id / $sender_rate / $sender_rate_period
accept
acl_check_spammers:
accept hosts = +whitelist
drop message = Your host in blacklist on this server.
log_message = Host in blacklist
hosts = +spammers
accept
acl_check_mail:
deny condition = ${if eq{$sender_helo_name}{}}
message = HELO required before MAIL
drop message = Helo name contains an IP address (HELO was $sender_helo_name) and not is valid
condition = ${if match{$sender_helo_name}{\N((\d{1,3}[.-]\d{1,3}[.-]\d{1,3}[.-]\d{1,3})|([0-9a-f]{8})|([0-9A-F]{8}))\N}{yes}{no}}
condition = ${if match {${lookup dnsdb{>: defer_never,ptr=$sender_host_address}}\}{$sender_helo_name}{no}{yes}}
delay = 45s
drop condition = ${if isip{$sender_helo_name}}
message = Access denied - Invalid HELO name (See RFC2821 4.1.3)
drop condition = ${if eq{[$interface_address]}{$sender_helo_name}}
message = $interface_address is _my_ address
accept
acl_check_rcpt:
accept hosts = :
# Limit per email account for SMTP auhenticated users
deny message = Email account $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
set acl_c_msg_limit = ${if exists{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{${lookup {$authenticated_id} lsearch{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{$value}{${readfile{/etc/exim4/limit.conf}}}}}{${readfile{/etc/exim4/limit.conf}}} }
ratelimit = $acl_c_msg_limit / 1h / strict/ $authenticated_id
warn ratelimit = ${eval:$acl_c_msg_limit / 2} / 1h / strict / $authenticated_id
log_message = Sender rate [limitlog]: log / email / $authenticated_id / $sender_rate / $sender_rate_period
deny message = Restricted characters in address
domains = +local_domains
local_parts = ^[.] : ^.*[@%!/|]
domains = !+local_domains
local_parts = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
require verify = sender
accept hosts = +relay_from_hosts
control = submission
accept authenticated = *
control = submission/domain=
deny message = Rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text
hosts = !+whitelist
dnslists = ${readfile {/etc/exim4/dnsbl.conf}{:}}
require message = relay not permitted
domains = +local_domains : +relay_to_domains
deny message = smtp auth required
sender_domains = +local_domains
!authenticated = *
require verify = recipient
.ifdef CLAMD
warn set acl_m0 = no
warn condition = ${if exists {/etc/exim4/domains/$domain/antivirus}{yes}{no}}
set acl_m0 = yes
.endif
.ifdef SPAMASSASSIN
warn set acl_m1 = no
set acl_m3 = no
warn condition = ${if exists {/etc/exim4/domains/$domain/antispam}{yes}{no}}
set acl_m1 = yes
warn condition = ${if exists {/etc/exim4/domains/$domain/reject_spam}{yes}{no}}
set acl_m3 = yes
.endif
accept
acl_check_data:
.ifdef CLAMD
deny message = Message contains a virus ($malware_name) and has been rejected
malware = */defer_ok
condition = ${if eq{$acl_m0}{yes}{yes}{no}}
.endif
.ifdef SPAMASSASSIN
warn !authenticated = *
hosts = !+relay_from_hosts
condition = ${if < {$message_size}{1024K}}
condition = ${if eq{$acl_m1}{yes}{yes}{no}}
spam = debian-spamd:true/defer_ok
add_header = X-Spam-Score: $spam_score_int
add_header = X-Spam-Bar: $spam_bar
add_header = X-Spam-Report: $spam_report
set acl_m2 = $spam_score_int
warn condition = ${if !eq{$acl_m2}{} {yes}{no}}
condition = ${if >{$acl_m2}{SPAM_SCORE} {yes}{no}}
add_header = X-Spam-Status: Yes
message = SpamAssassin detected spam (from $sender_address to $recipients).
# Deny spam at high score if spam score > SPAM_REJECT_SCORE and delete_spam is enabled
deny message = This message scored $spam_score spam points
condition = ${if eq{$acl_m3}{yes}{yes}{no}}
condition = ${if >{$spam_score_int}{SPAM_REJECT_SCORE}{1}{0}}
.endif
accept
acl_check_mime:
deny message = Blacklisted file extension detected
condition = ${if match {${lc:$mime_filename}}{\N(\.ace|\.ade|\.adp|\.app|\.arj|\.asp|\.aspx|\.asx|\.bas|\.bat|\.cab|\.cer|\.chm|\.cmd|\.cnt|\.com|\.cpl|\.crt|\.csh|\.der|\.diagcab|\.dll|\.efi|\.exe|\.fla|\.fon|\.fxp|\.gadget|\.grp|\.hlp|\.hpj|\.hta|\.htc|\.img|\.inf|\.ins|\.iso|\.isp|\.its|\.jar|\.jnlp|\.js|\.jse|\.ksh|\.lib|\.lnk|\.mad|\.maf|\.mag|\.mam|\.maq|\.mar|\.mas|\.mat|\.mau|\.mav|\.maw|\.mcf|\.mda|\.mdb|\.mde|\.mdt|\.mdw|\.mdz|\.msc|\.msh|\.msh1|\.msh1xml|\.msh2|\.msh2xml|\.mshxml|\.msi|\.msp|\.mst|\.msu|\.ops|\.osd|\.pcd|\.pif|\.pl|\.plg|\.prf|\.prg|\.printerexport|\.ps1|\.ps1xml|\.ps2|\.ps2xml|\.psc1|\.psc2|\.psd1|\.psdm1|\.pst|\.py|\.pyc|\.pyo|\.pyw|\.pyz|\.pyzw|\.reg|\.scf|\.scr|\.sct|\.sfx|\.shb|\.shs|\.swf|\.sys|\.theme|\.tmp|\.ttf|\.url|\.vb|\.vba|\.vbe|\.vbp|\.vbs|\.vhd|\.vhdx|\.vsmacros|\.vsw|\.vxd|\.webpnp|\.website|\.wim|\.ws|\.wsc|\.wsf|\.wsh|\.xbap|\.xll|\.xnk)$\N}{1}{0}}
accept
# AUTHENTICATION CONFIGURATION #
begin authenticators
smtp_relay_login:
driver = plaintext
public_name = LOGIN
hide client_send = : SMTP_RELAY_USER : SMTP_RELAY_PASS
dovecot_plain:
driver = dovecot
public_name = PLAIN
server_socket = /var/run/dovecot/auth-client
server_set_id = $auth1
dovecot_login:
driver = dovecot
public_name = LOGIN
# ROUTERS CONFIGURATION #
# Specifies how addresses are handled #
begin routers
send_via_unauthenticated_smtp_relay:
driver = manualroute
address_data = SMTP_RELAY_HOST:SMTP_RELAY_PORT
require_files = SMTP_RELAY_FILE
condition = ${if eq{SMTP_RELAY_USER}{}}
transport = remote_smtp
route_list = * ${extract{1}{:}{$address_data}}::${extract{2}{:}{$address_data}}
no_more
no_verify
send_via_smtp_relay:
transport = smtp_relay_smtp
no_more
no_verify
dnslookup:
driver = dnslookup
no_more
userforward:
driver = redirect
check_local_user
file = $home/.forward
require_files = ${local_part}:+${home}/.forward
allow_filter
no_verify
no_expn
check_ancestor
file_transport = address_file
pipe_transport = address_pipe
reply_transport = address_reply
procmail:
driver = accept
check_local_user
require_files = ${local_part}:+${home}/.procmailrc:/usr/bin/procmail
transport = procmail
no_verify
autoreplay:
driver = accept
require_files = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg
condition = ${if exists{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg}{yes}{no}}
retry_use_local_part
transport = userautoreply
unseen
aliases:
driver = redirect
headers_add = X-redirected: yes
data = ${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
require_files = /etc/exim4/domains/$domain/aliases
redirect_router = dnslookup
unseen
localuser_fwd_only:
driver = accept
transport = devnull
condition = ${if exists{/etc/exim4/domains/$domain/fwd_only}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/fwd_only}{true}{false}}}}
localuser_spam:
driver = accept
transport = local_spam_delivery
condition = ${if eq {${if match{$h_X-Spam-Status:}{\N^Yes\N}{yes}{no}}} {${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{yes}{no_such_user}}}}
localuser:
driver = accept
transport = local_delivery
condition = ${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{true}{false}}
catchall:
driver = redirect
data = ${extract{1}{:}{${lookup{*@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
file_transport = local_delivery
terminate_alias:
driver = accept
transport = devnull
condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{true}{false}}
# TRANSPORTS CONFIGURATION #
begin transports
smtp_relay_smtp:
driver = smtp
remote_smtp:
driver = smtp
helo_data = ${lookup dnsdb{>: defer_never,ptr=$sending_ip_address}{${listextract{1}{$value}}}{$primary_hostname}}
dkim_domain = DKIM_DOMAIN
dkim_selector = mail
dkim_private_key = DKIM_PRIVATE_KEY
dkim_canon = relaxed
dkim_strict = 0
hosts_try_fastopen = !*.l.google.com
interface = ${if exists{OUTGOING_IP}{${readfile{OUTGOING_IP}}}}
procmail:
driver = pipe
command = "/usr/bin/procmail -d $local_part"
return_path_add
delivery_date_add
envelope_to_add
user = $local_part
initgroups
return_output
local_delivery:
driver = appendfile
maildir_format
maildir_use_size_file
user = ${extract{2}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}
group = mail
create_directory
directory_mode = 770
mode = 660
use_lockfile = no
delivery_date_add
envelope_to_add
return_path_add
directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
quota = ${extract{6}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}M
quota_warn_threshold = 75%
local_spam_delivery:
driver = appendfile
maildir_format
group = mail
create_directory
mode = 660
use_lockfile = no
delivery_date_add
envelope_to_add
return_path_add
directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}/.Spam"
quota_directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
dovecot_virtual_delivery:
driver = pipe
command = /usr/lib/dovecot/dovecot-lda -e -d $local_part@$domain -f $sender_address -a $original_local_part@$original_domain
delivery_date_add
envelope_to_add
return_path_add
log_output = true
log_defer_output = true
group = mail
return_output
driver = pipe
delivery_date_add
envelope_to_add
return_path_add
log_output = true
group = mail
return_output
driver = pipe
delivery_date_add
envelope_to_add
return_path_add
log_output = true
group = mail
return_output
driver = pipe
delivery_date_add
envelope_to_add
return_path_add
log_output = true
group = mail
return_output
driver = pipe
delivery_date_add
envelope_to_add
return_path_add
log_output = true
group = mail
return_output
address_pipe:
driver = pipe
return_output
address_file:
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
address_reply:
driver = autoreply
userautoreply:
driver = autoreply
file = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}.msg
from = "${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}@${lookup{$domain}dsearch{/etc/exim4/domains/}}"
headers = Content-Type: text/plain; charset=utf-8;\nContent-Transfer-Encoding: 8bit
subject = "${if def:h_Subject: {Autoreply: \"${rfc2047:$h_Subject:}\"} {Autoreply Message}}"
to = "${sender_address}"
devnull:
driver = appendfile
file = /dev/null
# RETRY CONFIGURATION #
begin retry
# Address or Domain Error Retries
* * F,2h,15m; G,16h,1h,1.5; F,4d,6h
# REWRITE CONFIGURATION #
begin rewrite
