Fail2ban doesn't work with roundcube
Hi
I have fail2ban working properly with hestia, but doesn’t work with roundcube.
systemctl status fail2ban.service
● fail2ban.service - Fail2Ban Service
     Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; vendor preset: enabled)
     Active: active (running) since Thu 2024-08-08 15:47:16 CEST; 2h 14min ago
       Docs: man:fail2ban(1)
   Main PID: 1862334 (fail2ban-server)
      Tasks: 19 (limit: 19099)
     Memory: 14.3M
        CPU: 30.801s
     CGroup: /system.slice/fail2ban.service
             └─1862334 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
fail2ban-client status
Status
|- Number of jail:      8
`- Jail list:   dovecot-iptables, exim-iptables, hestia-iptables, phpmyadmin-auth, recidive, roundcube-auth, ssh-iptables, vsftpd-iptables
My file jail.local have the follow configuration:
[roundcube-auth]
enabled  = true
filter   = roundcube-auth
action   = hestia[name=WEB]
logpath  = /var/log/roundcube/errors.log
maxretry = 5
But I try to connect more than five times on Roundcube and it doesn’t ban my ip.
¿Do I have to modify anything?
Hi @timwol,
Log path exists?
namei -mo /var/log/roundcube/errors.log
Hi sahsanu
I put
it appears
f: /var/log/roundcube/errors.log
 drwxr-xr-x root       root       /
 drwxr-xr-x root       root       var
 drwxrwxr-x root       syslog     log
 drwxr-x--x hestiamail hestiamail roundcube
 -rw-r--r-- hestiamail www-data   errors.log
greetings
fail2ban-client status roundcube-auth
Do you see your failed authentication attemps in file /var/log/roundcube/errors.log?
If you can’t see your attempts, show the output of this command:
grep -E 'config.*log_dir' /etc/roundcube/config.inc.php
Hi sahsanu
I put fail2ban-client status roundcube-auth
it appears
Status for the jail: roundcube-auth
|- Filter
|  |- Currently failed: 0
|  |- Total failed:     0
|  `- File list:        /var/log/roundcube/errors.log
`- Actions
   |- Currently banned: 0
   |- Total banned:     0
   `- Banned IP list:
greetings
Now this :wink:
Hi sahsanu
Yes
It appears
[08-Aug-2024 16:51:43 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 16:52:33 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 16:52:48 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
I put
grep -E ‘config.*log_dir’ /etc/roundcube/config.inc.php
it appears
$config["log_dir"] = "/var/log/roundcube/";
greetings
Ok, I see no problem.
Did you try only 3 times? Because you must try 5 times in 10 minutes.
Did you restart fail2ban?
systemctl restart fail2ban
Also, did you add your ip to ignoreip directive?
grep -r '^ignoreip' /etc/fail2ban
HI sahsanu
I only put 3 times but I tried more
[08-Aug-2024 17:11:24 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:11:49 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:12:02 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:12:31 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:12:47 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:13:27 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:13:42 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
there aren’t the ip banead
Yes. I restared fail2ba.
I’m going to restart another time to double check
greetings
Ok, I see the problem, seems you are accesing the webmail using a proxy so this is being added to the log (X-Forwarded-For: 192.145.38.206) but fail2ban regex used doesn’t know about that so it is not caching the failed logins.
The regex used is in this file: /etc/fail2ban/filter.d/roundcube-auth.conf
Hi sahsanu
I’ve restarted first
after theat I’ve tried seveeral times to enter roundcube
[08-Aug-2024 17:27:51 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:28:05 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:28:21 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:28:56 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:29:08 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:29:26 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
[08-Aug-2024 17:30:07 +0000]: <tgesrk97> IMAP Error: Login failed for [email protected] against localhost from 192.145.38.206 (X-Forwarded-For: 192.145.38.206). AUTHENTICATE PLAIN: Authentication failed. in /var/lib/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /?_task=login&_action=login)
and the Ip wasn’t banned
greetings
Hi sahsanu
But then what do I have to do?
I use norvpn to browse like you say
and I have another problem that I would like to discuss other day.
When I use wireguard to connect with my server to browse, I use the ip of norvpn, if I’m connected with nordvpn, or my router if I am without nordvpn, but it does not catch me the one from my server that is what I would like it to catch.
You mention it in case the two things are related.
greetings
Hi sahsanu
But then when I try to connect to my hestia, if the ban works. Why does it only fail me with roundcube?
greetings
The regex should work in your case but it doesn’t and I don’t know the reason, I should review the current regex but I’m too lazy to do so.
I don’t understand what you mean. Regex used for roundube failed logins and regex used for hestia failed logins are two different ones.
Is there a way to get Hestia to log why or what account is causing the fsil2ban ? It would help me troubleshoot what devices that are trying with old credentials.
Hi sahsanu
What I meant is that when I fail 5 times to enter hestia, if I ban the ip, but with roundcube it does not happen to me.
Don’t bother. I don’t want you to spend any more time with me. Too much help you’re giving me
greetings
That’s because regex are different and lines in log too.
If I’ve time I’ll take a look to the regex because it should work.
Hi sahsanu
no worries
Thanks so much
greetings
I can confirm this . also the [dovecot-iptables] is failing to match
2024-08-08 13:58:47,568 fail2ban.filter [3966854]: INFO [dovecot-iptables] Ignore ::1 by ignoreself rule
also the logs say
against localhost
where the regex is looking for ‘from localhost’
but I agree the
X-Forwarded-For: is also an issue
so right now in hestia there is there any checking brute force password attempts on roundcube . Also noticed hestia install rouncube from source
