Fail2ban WordPress the easy way
Found this article that makes fail2ban work easily with WordPress.
Just thought I would post a segment of it for anyone interested.
Configure Fail2Ban for WordPress
To protect the WordPress admin panel with Fail2Ban, you will need to download the Fail2ban filter configuration file for WordPress. You can download it with the following command:
$ sudo wget https://plugins.svn.wordpress.org/wp-fail2ban/trunk/filters.d/wordpress-hard.conf -O /etc/fail2ban/filter.d/wordpress.conf
Next, create a Jail for WordPress by editing the file jail.local:
$ sudo nano /etc/fail2ban/jail.d/wordpress.conf
Add the following lines:
[wordpress]
enabled = true
filter = wordpress
logpath = /var/log/auth.log
maxretry = 3
port = http,https
bantime = 300
Save and close the file when you are finished then restart the Fail2Ban service to apply the changes.
$ sudo systemctl restart fail2ban
Hi @liamgibbins, I was wondering if it would be possible to adapt this instructions to update crowdsec instead.
I see that wordpress is writing to auth.log. Does it in hestiacp or do we need a plugin for that?
Curstom plugin
Hello @liamgibbins, I have used your manual and I have not succeeded in configuring fail2ban.
What I have tried so far is to install the WordPress plugin that @eris proposed and then download the wordpress.conf with your command.
The filter in wordpress.conf doesn’t match the entries in /var/log/auth.log so… either it is another plugin or we have to remake the filters.
Crowdsec has its own wordpress plugin that communicates with crowdsec via api and is authentication via token, it also integrates with cloudflare (just read about it on there website).
Hmm don’t know why it didn’t work its direct from wordpress hmm weird.
Way back when I first installed WordPress I used:
Jail.
[wordpress]
enabled = true
ignoreip = [my primary ip I use to admin the server]
port = http,https
filter = wordpress
action = iptables-multiport[name=wordpress, port=“http,https”, protocol=tcp]
logpath = /var/log/apache2/domains/*.log
maxretry = 5
findtime = 600
bantime = 3600
I ment to do escalated banning but got busy and forgotten about it
Wordpress.conf:
[Definition]
failregex = .POST.(wp-login.php|xmlrpc.php).* 200
I will check this tomorrow (or in the early hours) but I think this should work, not close to my computer at the moment having family time
I might switch to crowdsec but this all depends on how testing goes and how well the devs respond to questions, will be finding out more on that one when I find time to get on there discord (probably next week at this rate).
To get it work you have to install WP-Fail2ban plugin also:
Nothing will work without this plugin.
thanks so much for that info
Hmm it did work ages ago, something must have changed somewhere will have another look later today or tomorrow.
Will have to look at the apache2 logs to see why it’s not logging 200 when a user fails a login
Thanks, this information helped me
