Feature, web terminal, is considered?
As I starting playing with the source, I want to test some kind of web terminal; I know that you internally discusses that (Idea: Terminal console in hestiacp) and have no plans to include it; but when I saw the code, templates/includes/panel.php there is some sort of develop abut it. How is that? Are you plan to include a web terminal, or why is this code there?
Yes, there are plans to include a web terminal and it should be available in next major release.
It will be added in 1.9 release …
But only time…
Nice. I’ll check that.
Hi Sir,
Thanks for your help. I wanted to ask, what is the default port for HestiaCP’s web terminal? I couldn’t find this information anywhere. I had previously changed the port, and now the page shows a message saying ā€œupgrade requiredā€, which I’m not sure about.
As far as I know, HestiaCP is still free and open-source, so I’m a bit confused by the upgrade message. I tried reverting the web terminal port back to its default, but I don’t know what the default port actually is.
Thanks in advance for your guidance!
Please do not revive a one year old thread, create a new one instead. Default port should be 8085.
