Gateway time-out Error code 504
hello
now days im facing to much Gateway time-out Error code 504 …
also some time websites open very slow. or some time worked fine.
what is the reason why im facing this error to much now. before it never happen
im using multiple php on sites. and mostly websites on wordpress
contabo hosting cpu 8 ram 30gb
please can u tell me how to fix this problem and for run websites fast
thank you
i was reading this post and im try it
but its give me error Error: invalid min format :: hst_backups
check screen short.
Put * between quotes eg “*”
beside that, i have no idea what you’re trying to do. Add nginx.conf as cronjob doesnt make sense, same for apache2.conf. Do you know how to modify files over ssh?
its not worked.
2024-10-06_14-11-01
Error: invalid min format :: “*”
i was read that this post and try to do this maybe fix the problem
here is link
you didnt answered my question, do you know how to adjust a config file? There is zero reference that you need to add a cronjob in this thread, just to increase the timeouts…
no i dont know but i can edit if u explain me pls. im tired its to much gateway error. pls help
please be sure you read this: Please read this, before you start!
ok i read it. but i think im already post all information what i know . even im contact the hosting provider they said there is no issue.
im checked ram using is also normal then what is the issue. why im facing to much gateway error. should i reinstall the server ? or any other way to help me to fix this issue pls
