Hestia deb packages
Trying to install hestia on ubuntu 20.04, done it few days ago and worked not sure what went wrong this time.
I get this output.
` Adding required repositories to proceed with installation:
() NGINX
) PHP
() Apache2
) MariaDB
(*) Hestia Control Panel
Updating currently installed packages, please wait…/
Installation Aborted
Install script does not match Hestia release version
Please use the installer from the release branch
To test the beta version you need to build the hestia deb packages and re-run the installer
./hst_autocompile.sh --hestia no
./hst-install.sh … --with-debs /tmp/hestiacp-src/debs
Error: Installation aborted
root@minix:~#
I have used the commands below, both times
wget https://raw.githubusercontent.com/hestiacp/hestiacp/master/install/hst-install-ubuntu.sh 1
bash hst-install-ubuntu.sh
Is there anything that i can do
Hi @root,
A recent change was introduced to prevent users from accidentally using the installer from the master branch when installing on production systems.
To perform a new install on Ubuntu 20.04 LTS at this time, you will need to compile the packages locally using the commands stated and install with the --with-debs switch. We will be introducing official support soon and this will no longer be required.
Hello @root
Due to the some changes with new features the 1.1.1 deb files used in this 20.04 installer are not up to date. Also issues with accidentally using 18.04 and other version made us decide to enforce this rule
wget https://raw.githubusercontent.com/hestiacp/hestiacp/master/src/hst_autocompile.sh
./hst_autocompile.sh --all no
this will take about 5 to 15 minutes depending on your server / VPS or VM
bash ./hst-install.sh your options --with-debs /tmp/hestiacp-src/debs
Any way all the help is really nice. Depending on still on going issues there will be in the near future a beta release.
Thanks for the help @eris
Can’t figure out the right commands here, can you add the commands that i need to pass, are this to be done before the install or when the install is stopped
Commands need to be executed before install
I can’t get it to work i tried first like this
wget https://github.com/hestiacp/hestiacp/blob/master/src/hst_autocompile.sh --all no
I got this result
wget: unrecognized option ‘–all’
Then i tried like this
wget https://github.com/hestiacp/hestiacp/blob/master/src/hst_autocompile.sh --hestia no
I get wget: unrecognized option ‘–hestia’
If i run
Then
sudo ./hst_autocompile.sh --all no
I get:
sudo: ./hst_autocompile.sh: command not found
Please use 2 dashes --all / --hestia
root@minix:~# wget https://github.com/hestiacp/hestiacp/blob/master/src/hst_autocompile.sh --all no
Usage: wget [OPTION]… [URL]…
It is
And then use
bash ./hst_autocompile.sh
It should work
./hst_autocompile.sh: line 6: syntax error near unexpected token `newline'
./hst_autocompile.sh: line 6: `< !DOCTYPE html>’
https://raw.githubusercontent.com/hestiacp/hestiacp/master/src/hst_autocompile.sh this is the file that can be wget the other one it the GitHub page
i get that error when i run the bash ./hst_autocompile.sh
I ignore it and same result on install, below are the commands i used
bash ./hst_autocompile.sh --all no
bash ./hst-install.sh --with-debs /tmp/hestiacp-src/debs
You will see some out put but it should keep on running
no, after i run bash ./hst_autocompile.sh --all no
It throws the error and nothing after
You should run
The raw version is the version with out any html
bash ./hst_autocompile.sh --all master no
bash ./hst-install-ubuntu.sh --with-debs /tmp/hestiacp-src/debs --apache yes --nginx yes ..etc
After running bash ./hst_autocompile.sh --all no
i get
And the result was the same
bash ./hst_autocompile.sh --all release no
for testing, I would suggest to use the master branch:
Correct, my mistake, all good the compile is running now
